Old 08-09-2014, 08:47 PM   #1
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Question Guide Plate Preference?
On canted valve engines, is there a brand of guide plate preferred by most? BB Chev, Cleveland and 385 series Fords for instance.
Dave Turner
SS/GT #1153
Old 08-09-2014, 09:42 PM   #2
Tim H
Tim H's Avatar
Liked 481 Times in 158 Posts
Default Re: Guide Plate Preference?
Hey Dave,
Really like the adjustable DART guide plates on my BBC.
Old 08-09-2014, 10:02 PM   #3
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
I have seen lots of 351C engines with Manley guide plates.
42163-8 for 5/16" pushrod
42156-8 for 3/8" pushrod
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 08-10-2014, 08:37 AM   #4
Liked 1,826 Times in 414 Posts
I prefer the GM plate on my big block Chevy engines, if I'm using a GM head.
For aftermarket heads, I usually try to use plates that are adjustable.
Old 08-10-2014, 08:53 AM   #5
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
The ones with stepped up tips.....you want the point of contact as close to the rocker as possible, because the pushrod moves to the side throughout its lift, (unless you have perfectly inline pushrods/lifters) and canted engines do not.
The correct way is utilizing a 42/46 lifter location along with (on 351 fords) a 1.850 or larger lifter spread to minimize this. The 42/46 location works well on BBFords as well
If one is to operate in extreme rpm range valvetrain geometry is the most important issue to get right.
Notice that I said valvetrain geo, that means the whole system.
If the rules do not allow the modifications that I stated than you revert back to my first sentence.....step the ends up as close as possible to the tips.
The store bought Manely's as stated above are the best off the shelf piece for Fords as BBChevy already have rotated lifters
Just one of the obstacles to overcome when building a 2hp per CI stocker...Wait...., the toothpaste is out of the tube now...
Bill Diehl is offline   Reply With Quote
