Old 07-29-2014, 08:01 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default 3 speed in SS, which trans with brake
Racers,
when using a 3 speed with brake which trans do you run? SBC, about 600 horse, 3100 pound car,
Larry Woodfin 471W
Old 07-29-2014, 08:09 PM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: 3 speed in SS, which trans with brake
pro-trans. give the guys at A-1 a call and they will set you up.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 07-29-2014, 11:07 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 858 Times in 234 Posts
If it's a Bracket car , a more economical alternative to the Pro Trans would be a TH350 with a Coan trans brake valve body.
I've built many of these , and with the addition of the TH400 int sprag they are very durable. ....I have some Bracket racers who go 250 runs or more between freshen ups.
Defiantly not as quick as the Pro Trans and no clean neutral, but way less expensive .
Old 07-30-2014, 04:15 AM   #4
Dragsinger
Tom,
SS GT/TB with 327, the 585 Holley combo. A $5,500.00 plus trans is not in my budget for the initial construction so most likely I will begin with a powerglide w/brake. [I have plenty of powerglide parts]
Larry Woodfin 471W
Old 07-30-2014, 11:49 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,909 Times in 573 Posts
Originally Posted by Dragsinger View Post
Tom,
good choice using the powerglide to set up a new car. I am still using a powerglide in my car but am going to try a 350 turbo soon to see how the car likes it.
Mike Pearson 2485 SS
Old 07-30-2014, 12:56 PM   #6
Tom Goldman
The TH350 ,if the stock 2.48 first gear suits your combo, can be built with an aluminum drum ,TH 400 int sprag , trans brake valvebody for less than half the cost of the Pro Trans.
I would venture a guess that the performance advantage of the Pro Trans over the TH35 would be about .080-.120 second. depending on the ratios used.
Old 07-30-2014, 07:17 PM   #7
MAURICE BLENDHEIM
Liked 278 Times in 86 Posts
Tom…I do believe the TH350 has a 2.52 first stock and the TH400 has a 2.48 stock. MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 07-30-2014, 08:20 PM   #8
Mark Markow
I think Tom is right. a lo-buck th350 would be faster than the glide in your application.
Mark Markow
171 ss/tb
Old 07-31-2014, 11:50 AM   #9
Bench Racer
Liked 99 Times in 21 Posts
I remember talking to Joe LoCicero years ago about his SS car and he sad "if I want to go fast I run a turbo, If I want to win rounds I run a glide" Don Jackson
Bench Racer is offline   Reply With Quote
Old 07-31-2014, 08:05 PM   #10
Dragsinger
In the 2000 - 2002 season I raced an IHRA Crate Motor stocker. The initial build up was with a 200 trans. In the fall of 2000 the 3 speed broke and I swapped in a powerglide to make an up-coming race.
The car was sooo much easier to stage [smoother, less harsh] and became dead-on consistent. With the powerglide I won more and was more relaxed when driving.
Never reinstalled the 200 trans.
Larry Woodfin 471W
