Old 07-07-2014, 07:22 AM   #1
Liked 10,708 Times in 2,229 Posts
Default Goodyear 4457 Radial
156 runs and counting! Tom Losket checked the tread depth at 153 runs and it checked 4/32". Best 60' 1.29, in my A/SA @ 3410 lbs. 550+ Ft./lbs. torque.
It's the best tire I have ever had on my car, and it looks like it will be the cheapest.
Old 07-09-2014, 02:22 AM   #2
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: Goodyear 4457 Radial
Wow, that's impressive. Can I ask about your burnout technique ?
Dave Noll, EF/S ,?/SA 6526
Old 07-09-2014, 12:41 PM   #3
Murray4407
Murray4407's Avatar
X2 on the burnout ...
I'll be looking for a new set after this next divisional, might give them a try.
Murray4407 is offline   Reply With Quote
Old 07-09-2014, 01:58 PM   #4
I try to keep wheel speed low, second gear only, so the tire remains as flat as possible and the tire does not crown. Start at 5700 and as the tires clean it will start to drag the engine down below 5600 let go of line lock and ease out of the water while slowly reducing power.
Old 07-10-2014, 05:35 AM   #5
nickh
nickh's Avatar
Liked 642 Times in 192 Posts
How often are you swapping side to side?
nickh is online now   Reply With Quote
Old 07-10-2014, 06:59 AM   #6
Eight to ten runs
Old 07-10-2014, 05:17 PM   #7
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
Larry,
A couple more questions since you seem to be in answer mode.
1. How wide a wheel do you use?
2. Are they mounted tubeless?
3. Approximately what air pressure do you run?
4. Do the tires leak air between races?
Thanks in advance.
Larry Merk
Larry Merk is online now   Reply With Quote
Old 07-10-2014, 05:32 PM   #8
GUMP
Liked 2,354 Times in 554 Posts
I have them on both of my COPO Camaros and love them. These are my answers to your questions.
1. How wide a wheel do you use? 10"
2. Are they mounted tubeless? Yes
3. Approximately what air pressure do you run? 19 PSI
4. Do the tires leak air between races? No
Old 07-11-2014, 08:41 AM   #9
Larry
1. 9'' or 10'' I have both, never know when a flat might happen.
2. yes
3. 20 lbs.
4. little if any.
5. Very little rubber sticks to the car, most of it brushes off quite easily.
Old 07-11-2014, 01:32 PM   #10
Peter Ash
Peter Ash's Avatar
I am thinking this may be my next tire choice.
What is the cross section width on a 10" rim?
Thanks
Peter Ash 6100 STK
Peter Ash is offline   Reply With Quote
