Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 05-15-2014, 11:04 AM   #1
firebird
Default ss/cs queston
nhra rule book says that fiberglass is limited to the hood----does that allow an after market hood? If so can you use a cowl induction hood with a legal size scoop on it? Thanks
firebird is offline   Reply With Quote
Old 05-15-2014, 12:27 PM   #2
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: ss/cs queston
Aftermarket hoods allowed, however, there are scoop size limitations as regards to size. I believe the scoop you intend to use, will not meet the criteria. Check this site's classified section. I believe there are a few legal ones for sale.
Old 05-15-2014, 04:20 PM   #3
FED 387
Liked 333 Times in 180 Posts
ya get 11 inches from the original hood surface to the top of the scoop opening measured vertically--- if ya can get a cowl hood and hood scoop at/under 11 inches ya should be OK otherwise not acceptable--- thats the way I read it--FED 387
Old 05-26-2014, 02:14 AM   #4
Adger Smith
Liked 880 Times in 311 Posts
The first picture is not legal the second
Adger Smith (Former SS)
Old 05-26-2014, 02:20 AM   #5
Adger Smith
This is legal Both scoops in the pictures are mounted on Glass hoods.
I have seen a cowl hood be deemed legal, but it was just like said by FED... under 11 inches
