Old 10-21-2013, 09:45 PM   #1
Duster 318
Default tire size and gear ratio
I have 28 inch tall tires and a 4.30 gear and I want to put 29.5 radials on my 318 duster would this affect my e.t. and mph? and what gear should I have in it for the bigger tires?
Duster 318 is offline   Reply With Quote
Old 10-21-2013, 11:28 PM   #2
JimL
Default Re: tire size and gear ratio
Just looking at tire size/gear ratios, the closest to what you have now would be a 4.56 gear. As far as the et and mph, you have to look at the power curve of your engine and the rpm you want to cross the finish line.
JimL is offline   Reply With Quote
Old 10-22-2013, 08:45 AM   #3
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 306 Times in 103 Posts
MPH X Gear ratio X 336 divided by tire height = RPM . you can calculate difference and figure what you need to get rpm you want.
Auto will be slightly higher depending on % of converter slip,can also determine how good converter is working roughly anyway.
Stick will come out just about dead on calculation.
Mike Taylor 3601
Old 10-22-2013, 09:46 AM   #4
mannymen
Liked 13 Times in 7 Posts
Try this formula 26.4/28= ? X your gear = actual ratio.
My wording may not be correct, but whatever.
What is your stroke, vehicle weight and 1st gear ratio?
N/A
mannymen is offline   Reply With Quote
Old 10-22-2013, 11:24 AM   #5
Jim Kaekel
Liked 531 Times in 108 Posts
Don't forget that radials do not grow.
Jim Kaekel 3836 STK
Old 10-22-2013, 12:01 PM   #6
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
when comparing like size slicks, radials will increase your trap RPM by 200-300.
Old 10-22-2013, 04:38 PM   #7
Duster 318
thanks for the help i want to try the 29.5 radials with a 4.88 gear
