Liked 276 Times in 27 Posts
I received this info yesterday from NHRA....
"AMC 66-72 removed optional cam, carb, and intake as they were a dealer option not a factory option." For verification go to www.NHRARacer.com and check the Engine Specs and see that the optional carb, intake and camshaft has been removed effective 4/16/13. They are no longer on the engine spec sheet and will no longer be allowed in Stock or S/S. |
Liked 10,711 Times in 2,230 Posts
Now if NHRA would only fix all the Ford FE stuff: crank, rods, carbs, cam, and intake.
Liked 66 Times in 30 Posts
This reminds me of the recent hemi head saga. You'd think NHRA would FULLY investigate a request, make a decision based on ALL the pertinent information, and then stick by it. Flopping back and forth on an issue does nothing for their credibility and costs racers money for no reason.
The only guys to benefit from this one were the guys on eBay that were selling those old AMC/Edelbrock intakes, for a while the value of their junk soared! |
Liked 32 Times in 19 Posts
Who do you suppose was jealous enough to focus on the AMC? Only one or two in the country. To quote famous Tech men, "Its all dial in anyway". Anyone know if the bogus specs on 400 chevy changed yet? Any one know if the HP of the 71 Vette has been reduced to correlate with losing the Cold Air hood yet? Answers probably all NO. Just a case of attention to detail of ONE point, not in general. Maybe political...even if was reasonable by itself, So are the others...
Liked 685 Times in 204 Posts
I am glad I did not buy the Hornet I was looking at. To bad NHRA changed the rules, it would have been a fun car. Dyno
Liked 279 Times in 68 Posts
The only reason that stuff got approved to start with is that the person approving it didn't have a clue.
Greg Hill 4171 STK |
Liked 172 Times in 81 Posts
Good for NHRA, the group 19 parts never should have been included in S/SS. I didn't check to see if they removed the reference to flat top pistons for the 360, they were another bogus item.
Now that NHRA his come down heavy on those of us in the minority, hopefully they correct some of the issues affecting the majority. Jim Mantle V/SA 6632. |
Liked 316 Times in 67 Posts
Hey! whose the contact guy for some changes we'd like? yeah! swap out our 57 year old WCFB's for a couple of replacement little Holley's or AFB's (either one, don't care)
Also, if it takes about a half a year to correct it back, that's OK too, we'd be fast for awhile Who do we petition? Thanks in advance |
Cannibalism????
Ed Fernandez Veteran Member Posts: 5,290 Default Re: Could a SC/360 Hornet be a viable combination for stock? Hold on to your money till next year.Wouldn't want to throw good money at bad.That's all I'll say. __________________ Former NHRA #1945 Former IHRA #1945 T/SA
Steve Obertanec |
Liked 1,583 Times in 582 Posts
I am not biased to any make or brand, nevertheless, the parts are catalog, over the counter items just like all other makes did at the time.
If you take a close look at the specs for many other makes, they also benefited of the same type of parts. Is this some sort of prejudice on a car make that happens to be a minority in the classes? How did the Chevy 283 got to use a 327 intake? How do the Chevy 396/375 cam specs clear the piston dome without modification? Ford engines using camshafts that were only available over the counter only? C-4 bell housings that fit FE engines? Mopar 273 with Edelbrock intakes; over the counter item? Boss 351 with a Holley carb? 1967 Ford Fairlane 427/2x4 with an automatic? The list can go on and on.... Are the other makes afraid of an AMC beating them in class? |
