#11 |
Liked 49 Times in 15 Posts
At 28 lbs for a tall fill bucket of HardBlock, it's about equal to the weight of a sleeved block.
Just remember that you cannot use a 4 bolt block. You may want to try using a 307 block. I have a sleeved 350 block and a sleeved 307 block and I prefer the 307.
Dean Feiock -- Stock 5002 |
#12 |
Liked 279 Times in 68 Posts
Why can't you run a 4 bolt main block?
Greg Hill 4171 STK |
#13 |
I'm interested in the answer to this as well.
I'm sure the Dart Block that Bub suggests is 4 bolt. I don't see the part number in the accepted parts list yet, just the 4.00" bore SHP. Does anyone have information on whether it will be added soon? I could also drive 1.5 hours to pick up a (factory) 4 bolt main 305 block. I wouldn't want to get either of these and have them end up being illegal. Jeremy |
#14 |
#15 |
Liked 319 Times in 68 Posts
Talked to Dart Today , Not making small bore shp block due to engineering problems. Not planning to make them in the future,
Lee Valentine 1661 STK |
#16 | |
Liked 481 Times in 158 Posts
#17 |
I haven't seen this one either. A friend of mine saw it and told me it was for sale. Came in Canadian service trucks/vans.
Sounds like the small bore Dart block is a no go. If I carry the 4 bolt main 305 around, maybe the sleeved 4 bolt main 350 will be deemed legal. Or maybe the filled 305 blocks will be just fine, looks like they are a common option. Thanks for the input thus far. Jeremy |
#18 |
Liked 60 Times in 12 Posts
I had one about 10 yrs ago. Had I known I was going to try Stock, I would have kept it ! Came out of a Generac Natural Gas Genset off the rear of a Dr's office. 5.0L /w 4 bolt mains. I sold it to a guy who had a round track truck.
2894 STK |
#19 |
I won't debate the issue of their existance. I'm quite sure that in the US market, in GM production passenger cars and trucks, GM never installed a 4 bolt, 2 piece rear main seal, 305 block.
Among all the wording in the rule book, it states "no export, marine, or special equipment". That was the reason I was given when I asked years ago. Which in a nutshell means power plant, marine, and over the border parts don't qualify for stocker use (in most cases). I have not seen one, but I am told the pallet of small bore Bowtie blocks that Patterson bought are two bolt to comply with the rules. To be honest, at 400 HP, a good two bolt block with nodular caps and high quality sleeves is more than adequate.
Dean Feiock -- Stock 5002 Last edited by Dean Feiock; 09-12-2012 at 10:40 PM. |
#20 |
Liked 72 Times in 27 Posts
After approving the Dart SHP block for stock and superstock, do you really think that NHRA cares what you do with your $50 305 block? Do you think they are ever going to look at a bottom of an engine again?
