Liked 165 Times in 59 Posts
just fired up the amx last weekend and hope to get some track time in the last week of august ,i just put in some conventional 80/90 to at least start and run the car ,what are you guys running for oil in your jerico dr4 for fluid and are you running synthetic or conventional and issues with either oil,,, gmonde
www.gmondeperformance.com |
Liked 652 Times in 184 Posts
I run 75w90 synthetic mobil. Just pulled the top off mine and it looks brand new still.
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA |
I use 75/90 Torrco and have hundreds of passes on my Jerico. Always looks new. But I guess Torrco is no longer around?
Jeff Lee 7494 D/S '70 AMX |
![]() Well mine has 50 but our whole family runs Jerico dr4's and some are in the 200 pass range and they all look great and we all run the same 75w90 mobil. I think any good 75w90 would be fine honestly.
Light weight red line. One Quart. Never had a single problem.
Liked 779 Times in 193 Posts
Mobil 1 75-90
Liked 1,428 Times in 296 Posts
I think any synthetic would be fine, but I really like the lightweight redline. I have been using that for about 6 years now. 1 quart. The big thing is to change it out periodically. I change it once during the season and again in the off season when we look it over. Never had any lube related issues, but I have seen some where they never changed the fluid out and cleaned the magnet. More junk running around inside is not a good thing. The magnet is strong,but it will get "full" of stuff if you don't tend to it once in awhile. I also added some good side drain plugs with rare earth magnets to grab as much debris from wear that I can.
James Schaechter 3163 STK |
Liked 8 Times in 7 Posts
is that redline's shockproof you guys are talking about?
i run it in my harley...
without losers,winning means nothing. |
Yes. It's the lightweight shock proof gear oil. That stuff clings to the gears great. That's why you can get away with one quart.
