Old 07-05-2012, 05:37 PM   #21
Jim B
Default Re: Ring & Pinion Lube
Originally Posted by Myron Piatek View Post
To elaborate on this, the aftermarket, non-adjustable bearings normally used on Mopar rear ends are the sealed "Green" bearings. The OEM adjustable versions may require gear lube. But I haven't looked at one, much less used one for decades.
The Mopar OEM 8 3/4 and Dana 60 axle bearings get packed in grease (like front wheel bearings) prior to pressing the assembly on the axle shaft. There is an inner grease seal in the housing that prevents rear end fluid from reaching the wheel bearings.
Jim B is offline   Reply With Quote
Old 07-05-2012, 09:17 PM   #22
Myron Piatek
Liked 138 Times in 51 Posts
Thumbs up Re: Ring & Pinion Lube
Thanks for refreshing my memory. At least I got the first part right.
I believe some of the other Mopar axles with c-clips and straight bearings use gear lube?
Old 07-05-2012, 09:48 PM   #23
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
You are correct! After pulling the rear apart I fully understand now. The rear in my car is a complete Moser fabricated unit using a stock housing. It is braced and has a Pro Gear and the axle bearings are sealed. I am still not comfortable with one quart and have put two quarts of Amsoil gear lube in. Boy, that aluminum chunk IS lighter than the iron one! Jim
Old 07-05-2012, 10:33 PM   #24
Phillip marvetz
Phillip marvetz's Avatar
Talking Re: Ring & Pinion Lube
You're going to get it for that,lol.
2009 V/SA Record Holder
Old 07-06-2012, 10:21 AM   #25
Jim Wahl
Jim Wahl's Avatar
Just seeing if you're listening! Jim
Old 07-06-2012, 11:31 AM   #26
Reed Granrt
I have a question or an observation,If you want to know how little friction you are creating--why not mount a EGT in the rear and hook it to a data-logger so you can get a play back and look at the run and then make changes.
reed
Reed Granrt is offline   Reply With Quote
Old 07-06-2012, 02:28 PM   #27
BlueOval Ralph
Banned
You can buy paint or tape kits that register temps.
reed
BlueOval Ralph is offline   Reply With Quote
Old 07-06-2012, 02:48 PM   #28
Ed Wright
Ed Wright's Avatar
Or, you could just watch the MPH clocks.
Ed Wright 4156 SS/JA
Old 07-06-2012, 02:49 PM   #29
BlueOval Ralph
Banned
reed
Old 07-06-2012, 04:41 PM   #30
Pvt Parts
Pvt Parts's Avatar
Back in the early days of Pro Stock, Bob Glidden fabricated a small sump like kick out in his rear end housing that had a bung welded in it for a heating element similar to a water heater, only smaller. The heater was plugged in between rounds to keep the gear oil up to temp. That was long before synthetic gear oil was up to speed.
