Old 07-05-2012, 01:53 AM   #11
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Question Re: Ring & Pinion Lube
I never realized how varied the opinions on this subject would be! It seems very much like engine oil. I got 6 PMs and not one recommended the same gear lube. All but one advised to use synthetic though. Now a question from you MoPar guys who use an 8.75 rear. How much lube do you use? The stock rear uses about 2.5 quarts. I have heard several guys say all you need is one quart if you have a spool. My red flag goes up when hearing that because you not only are lubeing the ring and pinion but also the axle bearings. I don't see how one quart would be adequate for that. Am I wrong? Jim
Old 07-05-2012, 07:25 AM   #12
Ed Wright
Ed Wright's Avatar
Default Re: Ring & Pinion Lube
Your not wrong. If you know Jimmy Bridges, ask him what he found about this. Unlike engine oil levels, it's not a windage thing.
Ed Wright 4156 SS/JA
Old 07-05-2012, 07:34 AM   #13
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
yes, you are wrong. Many Stock/Super stock racers run only 1 quart and so do I.
Old 07-05-2012, 08:13 AM   #14
Dragsinger
Liked 99 Times in 60 Posts
Jim, for most applications the axle bearings are sealed so they do not rely on the gear oil for lube. Check to see if that is the case for your combination.
And yes, it is very common to use 1 - 1 1/2 qts for gear oil. For my Firebird with a GM 12 bolt I run 1 1/2 qts. With our 9" fabricated housing I run 2 qts
Larry Woodfin 471W
Old 07-05-2012, 08:14 AM   #15
tj310
One of the reasons they put the level so high in a stock rear is so the side carrier bearings are bathed in oil. If you try to run at the stock level you will most likely see leaks as well as an associated power loss . idealy I would run it full to warm up and then drain out all but a litre to race. But that's alot of work and I 've only done it that way once or twice.---Trevor
Old 07-05-2012, 08:41 AM   #16
Ed Wright
Ed Wright's Avatar
Might be common, but that does not make it right. I was running one qt in my GM 12 bolt. At Indy last year James Lee was with me. He walked over to visit with Jimmy Bridges. Gear lube came up. James had been galding gears. Jimmy had done some testing on the bench with a clear cover. I don't remember the speed, but at some point all the lube ends up in the axle tubes. He said his was faster with more lube. At that time I added the other qt of lube. To my surprise I picked up almost 1/2 MPH there at Indy. Kept that gain after returning home. You may not believe it, but might want to test it for yourself. An extremely low HP car may see something different, but if it doesn't run quicker low on lube, why do it? Your results may vary. LOL
Btw, I use Royal Purple synthetic gear lube. Never a problem.
Old 07-05-2012, 09:27 AM   #17
KRatcliff
Liked 534 Times in 143 Posts
I saw the same thing from someone else that was running too little oil in a 12 bolt. I run 1.5 +/- qts of the Royal Purple and don't have a problem so far. As fast as your stuff is, I wouldn't change a thing.
KRatcliff is offline   Reply With Quote
Old 07-05-2012, 11:52 AM   #18
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Ring & Pinion Lube
To elaborate on this, the aftermarket, non-adjustable bearings normally used on Mopar rear ends are the sealed "Green" bearings. The OEM adjustable versions may require gear lube. But I haven't looked at one, much less used one for decades.
Old 07-05-2012, 12:28 PM   #19
Ed Wright
Ed Wright's Avatar
Thanks Kyle. Been using Royal Purple everything for some time now. Zero problems with anything. I need to find out where you have been buying oil. I'm paying way more than you for this stuff. NAPA has it, but wow! LOL
Old 07-05-2012, 03:49 PM   #20
John Dinkel
Liked 263 Times in 68 Posts
Thumbs up Re: Ring & Pinion Lube
I have used a quart for a long time. Add a little more if you want. Amsoil synthetic, Mobil 1 synthetic.....
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
