Old 01-10-2012, 04:44 PM   #1
StockerRook
Default Fuel Injectors
Guys and Gals,
I am about to purchase a set of injectors for my LT1 stocker motor. I think I know what lb. to get but I had a question if one brand is prefered over the other (ie. Bosch, Accel, Holley, etc..). Is there anything I should consider prior to purchase. Thanks for any help.
Chris
StockerRook is offline   Reply With Quote
Old 01-10-2012, 06:29 PM   #2
KRatcliff
Liked 524 Times in 141 Posts
Default Re: Fuel Injectors
Check your PM.
KRatcliff is offline   Reply With Quote
Old 01-10-2012, 06:32 PM   #3
Ed Wright
Ed Wright's Avatar
Bosch. ACCEL injectors are made by Bosch now. Avoid cheap crap like Venom, etc. 30 lb is plenty big enough. I would use 24 lb at 60 psi if it were me.
Ed Wright 4156 SS/JA
Old 01-10-2012, 06:56 PM   #4
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I bought Accel 24 lb injectors when I put my LT-1 together. I ran it at 55 lbs. fuel pressure.
The present owner has bigger injectors in it. I really don't think they are needed.....30lb'er's sound about right from the info I was able to gather from my data logger....
I had no probelm with the Accel's and had an Accel Gen VII ecu and data logger....and they are still in the car now....
Rich Biebel
S/C 1479
Stock 147R
Old 01-10-2012, 11:38 PM   #5
StockerRook
I appreciate the help gentlemen. Hopefully see you in Baytown in March
Old 01-11-2012, 09:43 AM   #6
Chad Rhodes
As dumb as it sounds, the ford motorsports ones are good, and if you thumb through a mustang magazine, you can usually find them pretty cheap.
Chad Rhodes 2113 I/SA
Old 01-11-2012, 10:12 AM   #7
KRatcliff
It isn't dumb. They are the ones we prefer and run.
Old 01-11-2012, 10:25 AM   #8
rawhide
Liked 7 Times in 5 Posts
Ford Racing (Ford Motorsports) has injectors available in 24-30-32-34-39-47-60-80 lb versions. They are USCAR connectors other than the 30 lb which are Jetronic/Minitmer. They also sell adapter kits to convert the connectors. All that I have looked at are either Bosch or Seimans.
regards, Roland
rawhide is offline   Reply With Quote
Old 01-11-2012, 10:39 AM   #9
Ed Wright
Ed Wright's Avatar
The Ford Motorsports injectors are Bosch. Just another place to buy them.
Old 01-11-2012, 11:10 AM   #10
KRatcliff
regards, Roland
The Ford 24, 30, and 42 lb injectors are Jetronic/Minitimer.
