Old 12-02-2011, 09:58 PM   #21
Robert Simpson
Liked 20 Times in 12 Posts
Default Re: roller rockers
Just got back from there. No there has not been a final rule on what is excepted. None of the manufactures knew what the final rule was ALL of them was waiting on Danny Gracia's ruling on the rockers. I think we will know something the next week or so. They did not even have a rule book there. Also the booth was real small and no was was attending it.
Robert
P.S. wait for the COPO!! Testing will happen this week...
Robert Simpson is offline   Reply With Quote
Old 12-08-2011, 02:05 PM   #22
Bobby Fazio
Bobby Fazio's Avatar
The print is out but the rulebook is still very broad on the rocker arms.
'65 Mustang SS/L & L/SA
Old 12-08-2011, 06:00 PM   #23
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Originally Posted by Chad Rhodes View Post
how did a question about roller rockers turn into a bitchfest about mufflers?
The same way a reprint of a 1955 Wally Parks editorial turned into a dissertation about carb options available for Y-block Fords!
Paul Merolla is offline   Reply With Quote
Old 12-09-2011, 01:01 PM   #24
Mickey Whaley
Question Re: roller rockers
What is the final rule on rocker arms, anybody know???
Mickey Whaley is offline   Reply With Quote
Old 12-09-2011, 06:30 PM   #25
Jeff Teuton
Liked 325 Times in 50 Posts
It appears to me, the rockers have to be the same configuration as stock ie; a Mopar small (early) and big block must still run the same shaft configuration, but the needle bearing roller tip rockers are allowed, must be same ratio as blueprint specs. I don't think NHRA intent is to allow machining the top of the head for T & D, Jessel, or such. I think the intent is a stud mount must still be a stud mount, a shaft must remain a stock shaft location. Some people will be affected in that the specs might call for a 1.5, and of course there are usually no numbers on the stamped steel or ductile iron(Mopar), and almost all of the aftermarket has the ratio on them. Might affect camshaft etc, and is very easy to look at by Tech Inspectors. That is what got me pitched earlier. Cam checked, but the specs say 1.6 and I had 1.65 and I went home. That's my story and I'm sticking to it.
Jeff Teuton 4022 STK
Old 12-09-2011, 07:47 PM   #26
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
I spoke with Mr. Gracia at PRI and what Jeff posted is pretty much it. He told me he had looked at the Harland Sharp rockers and approved them. Yellow Terra Rockers submitted a set while at the show. Apparently almost any rocker, aluminum, steel, needle bearing, sleeved or whatever kind of roller tip is ok as long as it will directly replace the stock rocker with no machining and check at stock ratio spec. MoPars must use and fit stock shafts for example. Jim
Old 12-09-2011, 08:27 PM   #27
Mike Fuller
Liked 198 Times in 79 Posts
Thanks Jim!
Mike Fuller 396 STK
3961 SS
Old 12-09-2011, 08:36 PM   #28
Jeff Lee
Jeff Lee's Avatar
Bought mine from Comp Cams today!
Jeff Lee 7494 D/S '70 AMX
Old 12-10-2011, 03:42 AM   #29
Paul Merolla
Wow. My stuff just became fully obsolete. And it hasn't seen the track yet...yay. Keep it up, guys.
Old 12-10-2011, 05:52 AM   #30
Dean3870
x2
Dean3870 is offline   Reply With Quote
