Liked 165 Times in 51 Posts
How much ratio split between 1st & 2nd gear is the best?
Or should I say will be quicker? Last edited by MEXJOE; 04-04-2011 at 07:27 PM. |
Liked 685 Times in 204 Posts
I will ask 1st, what transmission? Snow gone up there yet? Dyno
Liked 2,485 Times in 697 Posts
There are a bucket of variables and options ( At least on our Pro Trans ). Can you share some information on your combination.
200 metric
325 hp 396 Camaro e/sa How much starting line ratio will be to much? Last edited by MEXJOE; 04-05-2011 at 10:25 AM. |
Liked 280 Times in 139 Posts
Glen, depends on the cam lobe centre, duration, shift point. With my combo if I hold it in first gear to long it will lose a tenth. John gsa 612
Liked 67 Times in 30 Posts
I would think the wider your powerband between peak tq and hp the more split
you could tolerate, with that being said its still some trial and error as some cars fall back more on the shift than others. converter, rear gears and weight all come into play but i think your big block may tolerate more split than a low tq small block.
Ron Mattson 5015 STK |
We currently have two E/SA cars.....71 Dart 340/314 and
73 Plymouth 440/345. Both have very aggressive cams in duration @ .050 (265+) and very close lobe center (106). I do not know what is normal because we march to beat of our own drum around here. As different as they are they both like 2.75 low and being short shifted out of low ( 400 - 500 below 2 - 3 shift. Hopes this helps. |
