#11 |
Liked 881 Times in 452 Posts
Have done any welding on the car?
#12 | |
Liked 165 Times in 59 Posts
#13 |
Liked 544 Times in 213 Posts
When it somes to welding on a racecar I can give you some advice.
I am Miller and Lincoln Certifed as a repair tech on their machines Mig welding is DC at fairly low voltage....around 20 volts and really all you need to do is keep you work clamp close to the weld site.....It certainly couln't hurt to go further and disconnect you ignition box or even remove it but it's not necessary.... The big issue with welders is HF used for arc starting with a Tig welder......and the arc coming out of a plasma cutter is similar to HF.....but even more likely to cause a problem with sensitive electronics..... At the very least anything electronic should be disconnected if your using a tig with HF or a plasma cutter....... Now someone will come on here and say he never removes anything and never hurt a thing.........thats the usual response on the Interent.....If it's my car I'm doing my best to protect my electronics.....
#14 |
I'm probably nuts, but my ECU and MSD box come out of the car before I tig weld on it.
Ed Wright 4156 SS/JA |
#15 |
You're definately not nuts Ed and I agree. My Lt-1 had to much stuff in it that could get hurt.......I did mig weld on the car and as I said never removed anything for that process......
I used a plasma cutter on a few vehicles over the years and had at least one that failed to start after the work I did. It was a work truck and I cut something in the rear suspension. Fuel pump circuit was killed in the ECU.....Ford. I rigged up a seperate circuit rather than replace the computer....Never used a plasma again on anything in the shop that had electronics attached to it....
#16 |
Liked 14 Times in 11 Posts
Thank you all for your comments and input. A local racer has offered
to loan me his good tested spare MSD 6AL and a good distributor so I can test everything and then replace the correct bad parts instead of just throwing money at it.
Phil Saran Parker, Colorado |
#17 | |
Liked 20 Times in 12 Posts
#18 |
Liked 68 Times in 26 Posts
hi, just a thought. I mounted my 7al2 on the floor panel passenger side, with rubber mounts, ran a ground to block. its way away from heat of any kind. been in car since 1990.
#19 |
Liked 7 Times in 6 Posts
I really thought I remembered the 6AL coming out in the late 80s or early 90s? I've had a few with only 1 problem, I sent it back out of warranty and as I recall, they repaired it for near nothing. Probably because it was an internal fuse . Call them and check cost, likely well worth sending in.
#20 |
That is how mine is, with a 10 ga ground wire directly to the back of the pass side cylinder head.
