Old 11-25-2010, 02:09 PM   #1
TinSoldier 3215
Liked 6 Times in 5 Posts
Default engines?
How often should you freshen a bracket motor? I have about 125 passes on my motor. thanks 1 season
TinSoldier 3215 is offline   Reply With Quote
Old 11-25-2010, 02:30 PM   #2
jmcarter
jmcarter's Avatar
Liked 3,180 Times in 972 Posts
Default Re: engines?
What kind of output and E.T are you talking about?
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 11-25-2010, 08:08 PM   #3
TinSoldier 3215
600 hp and runs 10.15 at 132.00
Old 11-25-2010, 08:23 PM   #4
Tim H
Tim H's Avatar
Liked 481 Times in 158 Posts
Aluminum rods ? makes a difference.
Old 11-26-2010, 06:59 AM   #5
jmcarter
jmcarter's Avatar
If it's running well and has good components (like premium rods) then 300 runs should be ok. Lots of variables like radical cams and RPM range but 200 runs would be the minimum you could expect to get out of it.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 12-01-2010, 09:53 PM   #6
et7333
et7333's Avatar
My 383 13-1 flat tappet,Iron eagle plat heads,has 500 runs on it and I'm just now going to freshen it.Motor is in my 68 camaro that weighs 3125 and runs 10.32@130 with a glide.
http://stevecoxracing.com
et7333 is offline   Reply With Quote
Old 12-05-2010, 09:56 AM   #7
HEADSUP113
if the engine has good stuff in it 300 is a safe # ck the liftes at this point. throw the rods away after 600 pass
HEADSUP113 is offline   Reply With Quote
Old 12-07-2010, 09:02 PM   #8
JHaleyH374
JHaleyH374's Avatar
If it has steel rods then 300-400 should be fine.
Jason Haley
86 Olds Cutlass bracket car
12.49@106, 7.79@87 best so far!
JHaleyH374 is offline   Reply With Quote
