Old 08-03-2010, 10:27 AM   #1
Cisco Kid
Cisco Kid's Avatar
Send a message via AIM to Cisco Kid
Default carb spacers
i have a simple question...i have to remove my throttle stop for a race,and my question is this...which 2" spacer to use,an open design or one with the 4 hole...i have a 4150 holley with an eldelbrock intake...i dont want to hurt the performance,since i have tested without using the stop,i would not mind gaining performance,but i dont want to lose any!!
Thanks
Cisco Kid is offline   Reply With Quote
Old 08-03-2010, 10:52 AM   #2
dbochan
Send a message via AIM to dbochan Send a message via Yahoo to dbochan
Default Re: carb spacers
For a smallblock with 4150, use and HVH Supersucker.
http://www.highvelocityheads.com/supersucker.html
dbochan is offline   Reply With Quote
Old 08-03-2010, 11:44 AM   #3
Cisco Kid
Cisco Kid's Avatar
so plastic is the way to go?? even for a bb?? thanks!!
Old 08-03-2010, 11:47 AM   #4
Bill Baer
I would think a four hole one would be a closer configuration to the four hole throttle stop your removing, a one hole would add pleneum volume, affect carb booster signal and possibly jetting.
If you have the opportunity to test and rejet it a one hole or super sucker [U]could[U] add a little performance.
Old 08-03-2010, 12:01 PM   #5
Cisco Kid
Cisco Kid's Avatar
now i been looking and i found these ones Phenolic SWIRL-TORQUE Spacers from trans-dapt and they are half the cost...i am planning on just using it for a race or 2 so i would like the least expensive but also keep the performance!! thanks again you guys are awesome!!
Old 08-03-2010, 02:07 PM   #6
Chris Williams
Chris Williams's Avatar
As Bill said, if this is a "swap in/swap out" kind of thing (run with the stop one weekend, not another) then I'd try to get a shape that exactly matches the stop. But if you're into fiddling/jetting/testing, then the sky's the limit...
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 08-03-2010, 10:18 PM   #7
Cisco Kid
Cisco Kid's Avatar
thanks guys!! i am just doing it for the unleashed race at national trails..i have started to remove all my electronics,and add weather pak connectors to everything...this is turning out to be a pain!!
Old 08-06-2010, 02:24 PM   #8
Michael Pliska
Are you sure they won't let you leave the stop in place with it disconnected? For running non-Electronics at NHRA National Opens and Summit ET series, I have an email from our division tech director confirming that it is okay to leave my Dedenbear on the car as long as the electrical wires are disconnected from it. That said, I have a Super-sucker on order to try and get my car closer to the 9.00 minimum for the ET finals (and I normally race 1/8-mile so I've got minimal 1/4-mile data anyway).
Michael Pliska 643 S/G
Michael Pliska is offline   Reply With Quote
Old 08-08-2010, 10:14 AM   #9
Cisco Kid
Cisco Kid's Avatar
michael,what i have done so far was make a electronics panel,that has my delay box and trans brake timer on it and installed weather pack connectors on all the boxes so i can easily remove them,the panel is also just mounted with dzus fastners,at or points meet at trails i talked with tech,and he said that i must remove all the electronics and even the stop off the intake...is it possible you can scan the letter you recieved and email it to me?? cause what i can do is leave it alone and just take the letter and my new spacer which cost 169 bucks and if i dont have to use it i will send it back...the rules are so vague that they tend to not explain the details,and i plan on testing next week to figure out my shift point to get down to 10.0...and i hate to change everything then have to go from square 1 on time trails...but thanks for you help...my email is seszko3@aol.com
thanks again
