Old 07-23-2010, 06:59 PM   #1
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default What coil to use????
I am switching from a MSD 7AL-2 ignition box to a (# 7520) digital-7 box..... I am running a #8201 MSD Pro Power Coil at this time.
Would I be better off to switch coils to a #8261, or can I stay with the #8201 coil with the new box?
TIA
Old 07-23-2010, 09:02 PM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: What coil to use????
Switch. It will be worth it in later rounds when the Pro Power would get hot and loose output.
Adger Smith (Former SS)
Old 07-24-2010, 04:57 PM   #3
Bill Harris
Liked 26 Times in 13 Posts
If you haven't bought the 7520 box yet and your 7AL2 is working fine, you should look into MSD's best kept secret, the #8979 box. It uses your existing analog 7AL2 and adds all the Digital-7 goodies to it, at way less cost than a 7520. Very nice unit, easy to hook up, saves $$ and keeps the nearly bulletproof 7AL2 as the main ignition. No sense getting rid of a perfectly good box, even though MSD would rather sell you a Digital-7, which is probably why they never talk about the #8979.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 07-24-2010, 09:21 PM   #4
james schaechter
Liked 1,428 Times in 296 Posts
The 8979 is actually better than the 7520. It adds programmable features like the 7530 programmables. I agree, you have to keep your eyes open. I bought one for under $200 with a hand held controller too.
As far as a coil. I run a Digi 7 programmable and use the HVC2 coil. I have had it in place since 2005. No issues. It's heavy though!
James Schaechter 3163 STK
Old 07-25-2010, 11:49 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,923 Times in 578 Posts
What are the real advantages of the digital conversion. I have the old reliable 7AL-2. I havent really thought about converting because of the cost. Is it really the way to go?
Mike Pearson 2485 SS
Old 07-25-2010, 02:49 PM   #6
Bill Harris
The digital box adds a bunch of features that you usually have to use external gizmos to implement with the 7AL2. Like rev-limiters for two steps, start retard, shift light driver, etc. The digital box does all that stuff plus it allows you to program cylinder-by-cylinder timing. It allows you to program a different shift light RPM in each gear, high side rev limit, burnout rev limit, start line rev limit.. all that kind of stuff. No RPM chips to lose and way more accurate than the purely analog pieces.
Bill Harris
ex 2172 STK
ex 2272 S/S
