Old 05-31-2010, 11:04 AM   #1
Joe DeMarzo
Liked 121 Times in 11 Posts
Default Q-Jet problem-help
All of a sudden my q-jet is giving me fits..... When I stage below 2600 rpm no problem, when I go above that to 2700 and up the secondaries open and push me in deep and it is like wrestling with an alligator at the starting line. Last year I could leave up to 3500 with no problem
I will accept all idea's here, pm, return reciept mail, telegraph or email. Very frustrating and distracting at the starting line.
Can anyone HELP an old alter boy.
Joe DeMarzo 1317 STK
Old 05-31-2010, 11:22 AM   #2
Liked 1,892 Times in 423 Posts
Default Re: Q-Jet problem-help
Joe,
Are you staging with or without a two step? Have you made ANY changes?
Old 05-31-2010, 11:27 AM   #3
Talking Re: Q-Jet problem-help
[QUOTE=Joe DeMarzo;189885]
Joe -- If I qualify call me .................
Old 05-31-2010, 12:13 PM   #4
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
Smile Re: Q-Jet problem-help
I have the solution, Joe. Put a stick in it! Lol!!!
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 05-31-2010, 12:31 PM   #5
Danny Ashley
Liked 110 Times in 29 Posts
Joe:
You know you can call me, right? I'm in the shop today. No rest for the weary.
Danny Ashley is offline   Reply With Quote
Old 05-31-2010, 01:06 PM   #6
Joe DeMarzo
Alan, old footbraker, no changes.
Danny will call tomorrow,
Joe, I would hurt myself with a stick, lol
Enjoy the day.
Old 05-31-2010, 04:05 PM   #7
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Maybe not the carb, but the rear brakes need adusting- if they are drums, or some other brake related issue.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 05-31-2010, 07:14 PM   #8
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
joe couldn't you just adjust the spring on the secondary flap a little stiffer?
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 05-31-2010, 08:09 PM   #9
Several things are possible.
As already mentioned, it could be brakes, however, it's not likely with your description, as less brake would mean less load. It wouldn't bring the secondaries in at a lower RPM, it would just push through the lights.
It could be a converter problem, if the converter has failed and is tightening up, you need more throttle to get the same RPM, and it pushes harder as well.
Or, the secondaries could have gotten looser, either from the spring getting soft or out of adjustment, or if you still have the choke pulloff, it could have gone bad. If the choke pulloff is there, and still hooked up to the secondaries, like it should be, it helps keep them OUT, unless it has failed, then it allows them to come in earlier.
Check the carburetor, then in a safe area, do a flash test, just mat the throttle from a high idle and see if the converter still flashes like it did before.
Old 06-01-2010, 07:22 AM   #10
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
I second that................
Bob Bender 144 O/SA
