Old 03-17-2010, 11:01 AM   #1
phillip wigington
phillip wigington's Avatar
Default fuel pump of choice"?
just curious? what is your fuel pump of choice! i run a bracket truck and have been having issues with the fuel pressure down track. its fine in low gear and when i shift to high gear it seems to POP! when under a load. like a lean out situation. i dont have a pressure gage visable while driving YET!!! lol i run 7.25 lbs at regulator and have checked everything under the sun so far... valves, fuel jets, timming, coil, any suggestions?? remember its only in high gear! even in the burn out. thanks DOES THIS SEEM TO BE A FUEL PRESSURE OR VOLUME ISSUE TO YOU? thanks phillip
Some days your the dog! Most days your the hydrant!.
phillip wigington is offline   Reply With Quote
Old 03-17-2010, 01:23 PM   #2
Bill Baer
Default Re: fuel pump of choice"?
Phil
Try reducing the gap on your spark plugs (-.010) and make a pass and see if the pop goes away. High gear is where the highest load occurs and that is usually where ignition problems show themselves.
Old 03-17-2010, 02:31 PM   #3
mannymen
Liked 13 Times in 7 Posts
I had a similar issue and talked to Product Eng about my fuel pressure setting for gas and the routing of the lines from regulator to the carb. I was running an adjustable fuel log at the time. Product Eng mentioned to bump up to 8.5 lbs and to keep the regulator in front of the motor with separate lines run from the regulator to the carb bowls. I haven't had your same problem since and he (can't remember his name) has seen many issues with fuel line routing and fuel logs causing regulator output issues. Hope this helps some
N/A
mannymen is offline   Reply With Quote
Old 03-17-2010, 08:06 PM   #4
d1hitter
Banned
cracked rotor.
d1hitter is offline   Reply With Quote
Old 05-09-2010, 12:29 AM   #5
rayfin
Had the same problem. Ditched my mechanical fuel pump and used an electric only. I think todays gas sucks.
rayfin is offline   Reply With Quote
Old 05-09-2010, 08:12 AM   #6
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
cracked distributor cap.check it good.
astikhossw is offline   Reply With Quote
Old 08-03-2010, 11:07 PM   #7
rayfin
Did you ever figure it out ?
