Old 02-26-2010, 01:04 PM   #1
Jeff Teuton
Liked 325 Times in 50 Posts
Default North Carolina Used Oil
Under NC 40 CFR 279.1 is the oil regs. The reg we need is .0118 Standards for Management of Used Oil, Subpart C Standards for Used Oil Generators (that's us), section 279.24 (a)(1)(2)(3) basically says less than 55 gals of Used Oil lets you off the hook for EPA numbers etc and you can transport it to a recycle center. There is an organization www.ecarcenter.org that is a association of oil recyclers that I think has the basic overview for each state. We have Used Oil, and we are not commercial users ie hobbiest, etc. Hope this helps. Remember we have Used Oil. That is a key to this situation.
Jeff Teuton 4022 STK
Old 02-26-2010, 06:30 PM   #2
herbjr
Liked 83 Times in 32 Posts
Default Re: North Carolina Used Oil
We have a waste oil heater and haul used all alot. That is true keep it under 55 gallons and have the drum Marked what it is and you have no problems.
herbjr is offline   Reply With Quote
Old 02-28-2010, 08:23 PM   #3
Chris1529
Liked 70 Times in 29 Posts
what about hauling 55 gals of used french fry grease to convert to bio diesel?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 02-28-2010, 10:42 PM   #4
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Add to the mix that NHRA doesn't own the track in NC.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 02-28-2010, 10:52 PM   #5
herbjr
AS long as its 55 gallons and it is marked to what it is no problem.
Herb Jr
