Old 02-16-2010, 04:06 PM   #1
CJohnson
CJohnson's Avatar
Default Best way to slow a car down ?
Just wondering if anybody has any experience on how to effectivley slowing a car down about 8 tenths to 1 sec. in order to into two classes. The car should run somewhere around 11.8 - 12.0 flat out. looking to slow it down to 12.8 to make the sportsman class brake.
Thanks.
CJohnson is offline   Reply With Quote
Old 02-17-2010, 07:40 PM   #2
Z28Racer93LT1
Default Re: Best way to slow a car down ?
Weight, shift lower, take timing out. That will get you there.
Z28Racer93LT1 is offline   Reply With Quote
Old 02-17-2010, 07:50 PM   #3
Mongo
I prefer lifting and or using the brakes.
Mongo is offline   Reply With Quote
Old 02-18-2010, 04:42 PM   #4
CJohnson
CJohnson's Avatar
Dumping a full 9 tenths ... no thanks
Old 02-18-2010, 05:27 PM   #5
d1hitter
Banned
put a FORD motor in it.
d1hitter is offline   Reply With Quote
Old 02-18-2010, 06:12 PM   #6
CJohnson
CJohnson's Avatar
Ya, that should do the trick.
Old 02-18-2010, 06:28 PM   #7
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Thanks.
Pull a bunch of timing ?
edit...Sorry didnt see someone else had already made the correct changes...Z28.....
Chris "drooze" Wertman is offline   Reply With Quote
Old 02-19-2010, 09:36 AM   #8
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
I'd try a restrictor plate under a spacer or disconnect the secondaries or restrict the throttle opening or all of the above.
Ron Gusack is offline   Reply With Quote
Old 02-19-2010, 09:42 AM   #9
Ron Gusack
Ron Gusack's Avatar
I'd try a restrictor plate under a spacer or disconnect the secondaries or restrict the throttle opening or all of the above. I took 3 seconds out of a 10 second car by only allowing the carb to open about a third of the way. I put a piece of aluminum on the underside of the pedal.
Old 02-19-2010, 11:06 AM   #10
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
The best way to do it is install a bolt under the gas pedal, and adjust it to limit full throttle until you get the result your looking for.
It works !
