#11 | |
1.) Assuming you are using a two-step, what rpm are you able to leave at? 2.) How much difference, if any, have you noticed with engine temperature being higher or lower in your et's? 3.) How in the heck do we figure out how to dial these things? I have noticed if we are running pretty close my car seems to fall off .05-.10 every pass. Is that pretty normal? Thanks for any help People tell me to just put a small block in it and forget this turbo stuff. But, I do like a challenge! |
#12 | |
Art Leong 2095 SS |
#13 |
Liked 53 Times in 25 Posts
What brand of computer are you using.
Dennis P Chapman 1904 STK NHRA National Record Holder Car Owner. |
#14 |
Stock Ford computer, MSD Ignition box.
#15 |
How much boost are you getting out of it.
#16 |
Also auto or stick.
#17 |
21 lbs. max. only 11 lbs. off the line. Automatic transmission conversion, car came stock with manual. max. rpm off the line is 2800 or it starts rolling the beams any higher. stock brakes and master cylinder.
#18 |
Whats your 60' and ET.
#19 |
Liked 5,121 Times in 1,952 Posts
Are you running it up against a 2 step on the line?
#20 |
two-step/ yes
i will get the log book this afternoon and give you guys the incrementals thanks again for the help; i really want to make this work |
