Old 07-23-2009, 11:31 AM   #1
Ben Kallies
Default Stock Eliminator - Any Valve Job?
I have a question regarding the new valve job rule that states: Any valve job allowed. Can I assume that this rule allows for back-cutting the valve to match the angles cut in the head? For instance, if I choose to do a 5-angle valve job instead of the old 3-angle, I would need to cut to the valve to match. Is this allowed? I didn't see it mentioned specifically in the rule book. Thank you.
-Ben
Ben Kallies is offline   Reply With Quote
Old 07-23-2009, 05:27 PM   #2
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Default Re: Stock Eliminator - Any Valve Job?
Ben,
Yes, correct. Actually, as many angles as you want.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 07-24-2009, 09:16 AM   #3
bobby
bobby's Avatar
Anybody ever do a radius seat instead of straight angles?
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
Old 07-24-2009, 09:45 AM   #4
BlueOval Ralph
Banned
Most of the Old Ford Factory Race engines had this!
429 Boss NASCAR
396 &427 FE NASCAR (now before every one goes into orbit about a 396 FE it was for NASCAR only in the 1967 Fairlane a special weight break! As I remember it was also a 2 four card intake also. Do your homework before you scream)
302 TransAm Boss
Ralph
I may still have a layout of the cutter
BlueOval Ralph is offline   Reply With Quote
Old 07-24-2009, 03:07 PM   #5
treessavoy
Liked 4 Times in 4 Posts
Dan Davorak does a seven angle valve job on his Max Wedge and has done this for years. The nhra used to give him crap about it but the rule book didn't say you couldn't have seven angles.
Jim Rountree
Old 07-27-2009, 09:02 AM   #6
Ben Kallies
Thank you to everyone who replied. I appreciate your input.
-Ben
