Old 06-09-2009, 10:31 AM   #11
bill dedman
Liked 6 Times in 4 Posts
Default Re: Steel caps for 8.75" Mopars???
Thanks again for all the good advice, guys!
This setup has new, Moser, hi-strength axles, a new cone-type Sure Grip, a crush sleeve eliminator, a new driveshaft with 7290 u-joints and 11/16" axle/wheel studs.... You're right; I'm probably not gonna hurt it footbraking it, with this ol' 360, boost, or no.
I really do appreciate all the good advice!!!
Bill
Bill
bill dedman is offline   Reply With Quote
Old 06-10-2009, 08:50 PM   #12
Frank Bialas
Frank Bialas's Avatar
Liked 23 Times in 13 Posts
Never enough money to do it right the first time, and than we do it right the second time.
If you think your alright than leave it alone, but remember this when it does break, now you also need a transmission fix and possibly a case too, the sprag doesn't like to be hit like that.
Frank Bialas 1570 STK
Frank Bialas is offline   Reply With Quote
Old 06-11-2009, 12:10 AM   #13
bill dedman
Your point is well-taken... I did put a crush-sleeve eliminator in it...
Bill
Old 06-11-2009, 10:23 AM   #14
John Dinkel
Liked 263 Times in 68 Posts
My suggestion is too find a 742 case. I broke a 489 with my stocker.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 06-11-2009, 11:14 AM   #15
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
John is right, find a 742 case. My 3500 lb. stocker has gone low 1.40 sixty foot with a 340. Last time I broke a rear end it was costly, it took out the trans and also damaged the thrust bearing in the motor. Contact Jim Bailey and have him process your gears and housing, it will help it last much longer.
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
Old 06-11-2009, 11:51 AM   #16
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Steel caps for 8.75" Mopars???
John and Chuck are right. Use a 742 case from the get go. Every gear I ever broke in the SS car was in a 489 case. Jim
Old 06-11-2009, 06:51 PM   #17
racerAL
racerAL's Avatar
Originally Posted by Sean Haning View Post
My 66 Belvedere with a 3500 converter, 440, slicks and 4.30 gears running low 7's never broke the 8 3/4. Who knows how old the center section was. I bought it used and was on stock axles for 3 years. So if its not your daily driver and you can't afford to beef up, just enjoy it until it needs it.
dittto......my 67 Satellite is set up almost identicle to this and i have had no problem with my stock 8 3/4. I'm running low 7's leaving off a trans brake ..i'm only running 4.10 gear though. [/IMG]...well i tried for a half hr. trying to post a pic of my heap...lol..ive posted pics of it all over the net but for some reason i can't do it on this site...no biggie you get the idea. run that rear-end till it breaks...imo
racerAL is offline   Reply With Quote
Old 06-11-2009, 06:55 PM   #18
bill dedman
Gotcha...
I have a 742 case on the floor in the garage. Got a 2.73 in it.... Bonneville, here I come!!!
No, I'll start buying parts for it as soon as there's some loose change around here; just spent each dime I could afford on a new driveshaft and that crush sleeve eliminator for the 489.
Now, lets see if this ol' 360 can do any damage to this much-maligned 489... LOL! New tires comin'...
Thanks, everyone, for all the good advice!!!
Bill
PS Al, mine's a 4.10, too...
Bill
Old 06-21-2009, 02:32 AM   #19
ET6201
Originally Posted by bill dedman View Post
Gotcha...
Bill
I've found the tapered pinion is ok, as long as the crush sleeve is replaced with the spacer. The last time I checked, the only pro gears for the 8-3/4" were for the 1-3/4" 'stepped' pinion gears (4.44 and 4.86:1 ratios). That's the only reason I went away from the tapered pinion.
I think the weak link is the differential. I've had both late and early Suregrips ('68 & '69 340-S Barracudas) and burned up both. As the late style wears out, it deposits trash in your gear oil. The ring & pinion don't like that.
The early type (that uses clutches) lasts longer. Another advantage is that you can just throw a new clutch pack at it, and be on your way. A machinist friend (L.D. 'Dennis' Smythe) has rebuilt the late 'cone' style but it involves milling some material off the small end of the cones and installing taller springs.
Early style Suregrips are hard to find, and expensive when you find one. On the other hand, spools are easy to find, and VERY hard to break!
Bryan (aka By-Run)
"Be a good sport at the drags...
help your competitor O-U-T!"
ET6201 is offline   Reply With Quote
Old 06-23-2009, 05:42 PM   #20
Michael Pliska
Who still makes pro gears for the 8-3/4"? Is my recollection correct that the above mentioned 1-3/4" stepped pinion is for 742 case?
Thanks,
Michael Pliska 643 S/G
Michael Pliska is offline   Reply With Quote
