Old 04-10-2009, 04:53 PM   #1
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default T-400 fluid?
I am sure this has been discussed to death, but my search has not answered my ???? satisfactorily......
I am running a T-400 with a manual ( Hypster, reverse pattern) valve body (drag race only application, no trans brake).
My question is. Going with the recommendations of my "trans guy" I run the Dexron III fluid. I liked that because it was easy to get/find....... Well I went to get my supply for the upcoming race season, and found it very hard to find. Can anyone clue me in on this? Why is the Dexron III going away? Can you "trans guys" tell me what I should substitute for my "old standby"?
I guess I could ask my "trans guy" but I have all this "been there, done that" information at my disposal, so I thought I would tap into it..TIA
Old 04-10-2009, 07:01 PM   #2
72Malibu
72Malibu's Avatar
Default Re: T-400 fluid?
I've been using Mobil 1, synthetic can take the heat better.
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 04-10-2009, 07:07 PM   #3
csjta
Dexron 6, good stuff, but it ain't cheap
csjta is offline   Reply With Quote
Old 04-10-2009, 08:57 PM   #4
njk53
Be careful using Dex VI. Dex VI is not compatable with the material that is used to manufacture some seals.
Nelson Kowal
Stock 345
Old 04-10-2009, 09:09 PM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
All GM Dextron fluids at back compatible. The newer fluids, were developed as an improvement on past fluids, and are more stabile, and maintain their viscosity better, cold to hot. Part of the reason for the new Dex 6 fluid is to have a 100,000 mile service life in cars running normal conditions. Heavy duty driving still needs fluid swaps as recommended in the owners manual.
Old 04-11-2009, 11:55 AM   #6
Tom Goldman
Tom Goldman's Avatar
Liked 881 Times in 236 Posts
Mopar ATF+4 also performs very well in race applications. .........holds up very well in high heatand has excelent anti foaming properties.....Even available at Walmart! ....I've been using it for about 5 years in both my stocker,a TH400,without a cooler, and my SG car, which runs in high gear all the way down the track. ......No wear problems,or clutch issues. .....Tom
Tom Goldman is online now   Reply With Quote
