Old 08-08-2025, 10:10 AM   #1
JCChildress
JCChildress's Avatar
Liked 13 Times in 6 Posts
Default Lightweight 12v Battery Recommendation
I'm sure this has probably been discussed a million times. I'm not interested in a Lithium battery. A 12v AGM battery, like for a stocker. Who makes a good, light battery that doesn't cost an arm and a leg ? While we're at it, who makes a good, battery charger that is compatible ? I kinda like the Schumacher SC1446 charger. I appreciate the help.
JCChildress is offline   Reply With Quote
Old 08-08-2025, 10:29 AM   #2
StockerStang912
StockerStang912's Avatar
Liked 21 Times in 7 Posts
Default Re: Lightweight 12v Battery Recommendation
We've had good luck with the Odyssey PC925...it's not super lightweight, but we've run 2 for 6 or 7 years now with no issues.
Greg Viscome
193 GT/QA
StockerStang912 is offline   Reply With Quote
Old 08-08-2025, 11:13 AM   #3
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
https://www.napaonline.com/en/p/PSBETX30L
I've had good luck with these. Only 20 lbs.
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 08-08-2025, 07:44 PM   #4
Bob Shaw
Liked 323 Times in 63 Posts
A battery for a Honda Fit weighs about 20 pounds. Top post. Walmart has 3 yr free replacement.
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 08-11-2025, 01:26 PM   #5
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
I've had good luck with Braille AGM batteries. The car has one up front and one in the trunk, so I get away with the 11 Lb size...not sure I would trust just one (360 cca) but they also have a 17 Lb with 475 cca. Pricing is decent, too. The 11 Lb is $205 at Summit.
I'm on my third set, just replacing them every 4 years to be safe.
Paul Merolla is offline   Reply With Quote
