Old 02-18-2025, 01:07 PM   #1
CraigG
Liked 9 Times in 8 Posts
Default How to Modify Stock '72 GM A body A Arms for more Travel?
Hey Everybody,
How to Modify Stock '72 GM A body A Arms for more Total Travel - upper A arms for right side at "4.5 to match the left at "5.5?
I already removed the rubber upper stops.
"1 Ball joint extension on right
What about this?
QA1 Ultimate Ball Joints 1210-299B
Thanks, Craig
CraigG is offline   Reply With Quote
Old 02-18-2025, 01:31 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: How to Modify Stock '72 GM A body A Arms for more Travel
Do a search on my old posts about my former Chevelle. BTW, I did not remove the stops and set the ride height to a specific air gap.
Old 02-19-2025, 06:15 AM   #3
M120
Liked 22 Times in 12 Posts
Unhappy Re: How to Modify Stock '72 GM A body A Arms for more Travel
Or you could tell him now. But you won't because you would do a disservice to your resume.
I have stock control arms with the loose bushings. I have moroso springs with old lakewood shocks. Over 5.5" of travel.
Stock type ball joints.
Get your ride height correct with the springs.
If I rebuild, I will look at landrum springs. I'm thinking I'd rather have a street car these days though.
Mark Mueller
FLC
M120 is offline   Reply With Quote
Old 02-19-2025, 07:14 AM   #4
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Pro Forge makes tall upper ball joints. That will get you more front suspension travel. It helps correct the upper an arm to be more parallel to the lower making car think it has a taller spindle. It helps correct the camber changes to neutral thru the travel doing this also. You may even have to limit travel actually. Your results may vary. This is my current personal experience. It?s cheap and easy. You will need an alignment of course. But it really helps the car track true down the 1/4 mile.
chris ok is offline   Reply With Quote
Old 02-19-2025, 10:10 AM   #5
L78 Nova
L78 Nova's Avatar
Liked 23 Times in 13 Posts
In my opinion, Howe Racing makes the nicest ball joints you can buy. Various length studs are available. Their website is a PIA to figure out PN's but once you know the #'s you can order from Summit.
L78 Nova is offline   Reply With Quote
Old 02-19-2025, 01:27 PM   #6
1320racer
1320racer's Avatar
Coleman ball joints are the best and what I had.
Old 02-19-2025, 10:36 PM   #7
CraigG
Replacing both uppers with the "1 extended ball joints will require what alignment change?
Toe-in or camber changes?
Thanks, Craig
Old 02-20-2025, 08:52 AM   #8
chris ok
chris ok's Avatar
Your car will have excess positive caster as your upper an arm will be moving up and out, so will need to be shimmed accordingly. I believe the toe in will also change then as the tires will pidgeon toe in needing correction.
I actually had to make limiters as my suspension travel was about 6.5?
