Old 01-19-2025, 04:01 PM   #1
SSGN
SSGN's Avatar
Liked 203 Times in 52 Posts
Question Best Fuel Pressure gauge?
Looking for input on the best 1 1/2 fuel rail/Regulator fuel pressure gauge? Brand and liquid filled vs standard. I have tried a few in the past and they were never very accurate when engine bay temps got warm and also didn't last long.
Thanks in advance
The more people I meet the more I like my dog
Kevin
Old 01-19-2025, 04:08 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Best Fuel Pressure gauge?
Kevin, I can't say whose is best but I can tell you that you don't want a liquid/glycerin filled gauge.
That said, my advice is to remove the gauge after the fuel pressure is set.
Old 01-19-2025, 04:11 PM   #3
Jeff Niceswanger
Liked 1,071 Times in 378 Posts
You want the stepper motor ones. Deadly accurate. They make them in 60-210 Water Temp also. This is a AutoMeter 4463-SP 0-100 . The also have 0-15 also. I have one (0-15) laying downstairs if that's what you need.
https://www.autometer.com/2-5-8-fuel...peak-warn.html
https://www.autometer.com/media/cata.../4/4470_30.jpg
Jeff Niceswanger 3740 SS
Old 01-19-2025, 06:48 PM   #4
Kirk Morgan
Liked 81 Times in 45 Posts
Thats interesting. I have found the liquid filled gauges to be accurate. At the instruction of Aeromotive i pull the rubber plug out of the gauge to equalize the pressure. We just installed a Race Pack and the reading on the gauge and the data logger were the same.
Kirk Morgan is offline   Reply With Quote
Old 01-19-2025, 06:58 PM   #5
1320racer
1320racer's Avatar
All that tells me is it’s not accurate.
Old 01-19-2025, 07:40 PM   #6
SSGN
SSGN's Avatar
I have heard the liquid filled gauge can change as the engine compartment gets hot the fluid changes viscosity. Thanks Jeff for the input also but I am only looking for small rail mounted unit. I just want to have a look at the fuel rail periodically. I have a 2 1/2 gauge with 3 ft hose to verify if I think there is a problem.
Kevin
Old 01-19-2025, 08:05 PM   #7
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
I had a couple of the cheap ones go bad. I bought liquid filled one from Red Horse, try that next
