Old 07-11-2024, 09:55 PM   #1
Doug Domm
Liked 85 Times in 22 Posts
Default Blower fan issue 2018 Silverado
The blower fan only runs for 3-4 seconds then quits, turn off the AC then turn the AC back on and fan only runs 3-4 seconds again. The fan will run at whatever speed was selected but only for that 3-4 seconds. Does the same thing operating the heater. Zero previous indication of the blower motor not being happy. A local AC tech with many years experience suggested disconnecting the battery for 10 minutes. Tried that and still the same issue. Thanks for any help. Doug
Doug Domm is offline   Reply With Quote
Old 07-13-2024, 01:47 PM   #2
340Cuda
Liked 805 Times in 341 Posts
Default Re: Blower fan issue 2018 Silverado
Just a wild guess, any chance it is on a circuit breaker rather than a fuse?
Good luck!
Old 07-13-2024, 10:46 PM   #3
FED 387
Liked 335 Times in 182 Posts
look into blower motor resistor--age of battery---cabin air filter ---all things to consider ----maybe blower motor itself ----not out of the realm of possibility---FED 387
Old 08-28-2024, 09:43 PM   #4
Doug Domm
It was the blower fan resistor. No resistor to be sold separately at any local supplier. I got a used blower fan with the resistor from a totaled 13,000 km truck and solved the problem. Nobody local had a new fan unit in stock either but I found that ultra low mileage used one from an insurance vehicle salvage operation.
