Liked 205 Times in 93 Posts
SS/GT cavalier...not sure which way to go. any advice please...i plan to run an alternator.
Liked 2,518 Times in 702 Posts
I you need the weight anyway = Why not run a
second battery. We do in our cars.
Liked 3,263 Times in 990 Posts
What’s nice about GT is class flexibility, if you need the weight then what John said. If you’re looking to be able to move up in classes occasionally then it’s a lot easier (and cleaner) to just remove weight bars.
would any ony have a battery cable diagram to hook up two batteries using charging lugs and required kill switch in the system...tks !
Liked 808 Times in 247 Posts
I totally agree that if you need weight, might as well be a second battery. One piece of advice that I learned the hard way, between races, separate and load test the batteries individually. If one of the batteries goes bad, it will take the other one down with it.
#6 | |
Liked 1,887 Times in 579 Posts
if you must run two batteries consider running an isolator you could even put a switch inside the car in case one battery goes dead. Hit the switch and you’re up and running.
