Old 04-06-2024, 06:03 PM   #1
Coleydog
Liked 53 Times in 38 Posts
Default Cal trac springs
A question for mopar a-body cars, what number spring are you using? Mono or split? I’m looking to buy and want input from the racers themselves not cal trac
Old 04-06-2024, 10:07 PM   #2
T Ames
T Ames's Avatar
Liked 125 Times in 33 Posts
Default Re: Cal trac springs
My stick 340 Duster application uses Calvert split monoleaf with front segment LF120-345 and rear segment PLR537-460. Relatively recently switched to that rear segment with higher spring rate and am very happy with it. May not work as well with an auto.
I have enjoyed working with the Calvert team over the years—they have always been very helpful in solving issues. They have customer service second to none.
T Ames is offline   Reply With Quote
Old 04-07-2024, 09:33 AM   #3
Gmirza
Liked 253 Times in 95 Posts
Calvert offers a 0, +1” and a -1” ride height spring combo. I went with the 0, the car sits level at #3200. Problem I ran into was now the 10” w, 4.5 bs wheels,9x30 Hoosiers no longer fit under the wheel wells. The +1” spring sits more like a #3000 SS spring. I do like the car lower in the rear. Nice thing is, like Tim did, you can simple change the rear half if you want to change the height.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 04-07-2024, 11:31 AM   #4
Coleydog
I see they have different front segments also, 120 and 121. What’s the purpose on that, stiffer? The post above and the one who pm-ed me use same rear section. Great info keep it coming
Old 04-08-2024, 03:48 PM   #5
GTX JOHN
As I remember, Calvert made a mono for the A bodys to allow
a bit more tire to spring clearance. It was narrower but I do not
think I have seen one the last 15 or 20 years. It helped on a early
Dart or Valiant but was not needed on a Duster/Demon style car.
John Irving
741 Stock
741 Super Stock
Old 04-08-2024, 07:42 PM   #6
Coleydog
I spoke with Cal today to clear up some things, got one more request (leave I bolt un drilled) so I’ll call again tomorrow to see if they’ll do that.
