Old 02-25-2024, 09:28 PM   #1
RonB
Liked 50 Times in 15 Posts
Default Mopar Radiator Hose P/N?
Installed a Meziere electric water pump on my 318 Volare and now need a different lower radiator hose. I’m hoping someone can provide a part number for a good fitting hose for this combo.
Thanks,
Ron B
RonB is offline   Reply With Quote
Old 02-26-2024, 08:23 AM   #2
Cotten
Liked 565 Times in 70 Posts
Default Re: Mopar Radiator Hose P/N?
Visualize what bends you need and then look at a parts store for something longer that is close and then cut to fit.
Possibly can use flex hose. Longer fitting or two 45 degree on pump can help.
Cotten is offline   Reply With Quote
Old 02-26-2024, 08:52 AM   #3
RonB
Thanks for the advice, Mike. I’m still hoping that somebody has found a good fitting molded hose and can share the P/N.
I think the A-body is the same as the F-body.
Ron B
Old 02-26-2024, 01:40 PM   #4
340Cuda
Liked 805 Times in 341 Posts
Ron,
You might also try the Moparts site.
https://board.moparts.org/ubbthreads/ubbthreads.php
