Old 08-02-2023, 11:54 AM   #1
Woodfin
Liked 288 Times in 109 Posts
Default Coating bare tubing
Some years ago, we used a kit that was similar to gun bluing to treat, stain, bare tubing. We did a complete dragster and it worked out fine. I do not remember any downside to the process. Like a gun, we would wipe it down from time to time but mostly it weathered just fine. Have any of y'all done this? Do you know the product?
Old 08-02-2023, 02:57 PM   #2
Crisco
Liked 47 Times in 21 Posts
Default Re: Coating bare tubing
Im not sure of the exact product you are wanting to use, but at my fab shop we use Gibbs oil to protect our bodies we build from rusting.
https://gibbsbrandlubricant.com/prod...-oz-spray-can/
Crisco is offline   Reply With Quote
Old 08-02-2023, 05:40 PM   #3
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
Larry,
Are you referring to "black oxide" coating which is similar to gun bluing? I have never used it but there are several companies that sell kits. Most appear to be oriented toward coating small parts via immersion.
https://www.epi.com/
https://birchwoodtechnologies.com
Larry Merk
Larry Merk is offline   Reply With Quote
Old 08-05-2023, 02:28 PM   #4
SSDiv6
One of the best products for protecting a roll cage, chassis parts, and components is Steel-It. Easy to spray and it needs to air-cure for a few days. After it cures, it will sustain solvents, oils, fuel, and chip resistant.
It is the preferred finish for Trophy Truck chassis and suspension components that are exposed and have to sustain the rough environment of desert racing.
https://steel-it.com/pages/motorsports-powersports
Old 08-05-2023, 08:05 PM   #5
Keith 944
Keith 944's Avatar
I have used something called sharkhide for bare metal. It’s pretty easy to work with and leaves the original finish
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
