Old 02-07-2023, 08:20 PM   #1
Mike Graham
Liked 341 Times in 67 Posts
Default Racepak o2 sensor
I found that th o2 sensor power was disconnected on a car I bought. I think this was about 5 runs ago with some moving and idling. Does this destroy the sensors?
Mike Graham is offline   Reply With Quote
Old 02-07-2023, 11:42 PM   #2
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: Racepak o2 sensor
That's powers the heater for the sensor. Without the heater, the sensor needs the exhaust to get it hot enough to produce a signal. Which is how the original single wire O2 sensors worked. Any damage to the sensor gets back to the age old argument, does leaded gas actually ruin O2 sensors?
Dave Noll, EF/S ,?/SA 6526
Old 02-08-2023, 10:24 AM   #3
Kirk Morgan
Liked 81 Times in 45 Posts
If you have a good volt meter IE Fluke or equivalent you can check it your self. You did not say what the application is but the voltage numbers will change very rapidly and depending on fuel mixture will range between .8 to .3 volts. You can make the fuel mixture rich or lean and see if the O2 sensor responds. Heated O2 sensors in my opinion are pretty tuff and take some extreme conditions to ruin them.
Kirk Morgan is offline   Reply With Quote
Old 02-08-2023, 12:27 PM   #4
Jim Caughlin
Liked 805 Times in 245 Posts
Originally Posted by Dave Noll View Post
That's powers the heater for the sensor. Without the heater the sensor needs the exhaust to get it hot enough to produce a signal. Which is how the original single wire O2 sensors worked. Any damage to the sensor gets back to the age old argument, does leaded gas actually ruin O2 sensors?
Yes, it absolutely does. They are a consumable part for the dyno. We have had this conversation with Superflow in the past and they agree that there is no fix, the leaded fuel just flat doesn't work with them longterm. We even tried reusing malfunctioning sensors on pump gas motors to see if they would 'clean out', no luck. Bosch seems to be the best but we have a large pile of burned out ones.
Jim Caughlin is online now   Reply With Quote
Old 02-08-2023, 04:29 PM   #5
Rob Petrie E395
Liked 216 Times in 77 Posts
A related question. If you had the choice between a fuel injection system with the Bosch sensor or a NTK sensor. Is the NTK worth $200 more? They claim they last longer with leaded fuel.
Old 02-08-2023, 05:33 PM   #6
Jim Caughlin
Our experience is that Bosch seem to live longest.
Old 02-08-2023, 09:35 PM   #7
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Rob,
Non related to the Racepak question. I killed a Bosch sensor after 6 dyno pulls and 2 passes when I switched to EFI. I switched to an NTK and they survive a full season. They are not cheap. I purchase a new one each year during Holley Days at a discount. BTW I run C-16, and have not had one fail.
Sean
Sean Marconette
84 Mustang
5060 SS/N
