Old 11-14-2022, 08:40 AM   #1
Matt S
Liked 20 Times in 12 Posts
Default Re-arch Calvert Mono Leaf?
Has anyone successfully re-arched Calvert mono leaf springs? I've got +1" height springs, and I still have trouble fitting a 30" tire on my '69 Camaro, even with extended shackles. Looks ridiculous with shackles that long. How is everyone fitting the 30x9? Can't do a whole bunch now because the car is painted, but a taller leaf spring would allow me to shorten the shackles back to stock length.
Matt S is offline   Reply With Quote
Old 11-14-2022, 09:27 AM   #2
Ralph A Powell
Liked 225 Times in 136 Posts
Default Re: Re-arch Calvert Mono Leaf?
Call Calvert and talk to them. They are user friendly.
Old 11-14-2022, 10:19 AM   #3
Matt S
Hi Ralph,
I actually did talk to Calvert over the summer, and they suggested no, which I completely understand a manufacturer not recommending a user to modify their product. I just wanted to ask and see if anyone has done it in practice. Certainly if there's a way to fit the bigger tire in the wheelwell without touching the springs I would prefer that. I could go to a shorter 28" tire, but I see everyone running the 30x9 so I'm confident it can be done.
Old 11-14-2022, 10:24 AM   #4
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Re-arch Calvert Mono Leaf?
Good morning to all,
I have a 1969 Chevy Nova body and years ago I found that arching the leaf spring 2" gave the body 4" of lift. This measurement also worked well on a friends 1969 Z/28 Stocker. Using a 4 1/2" to 5" back spaced wheel (rear) on a Camaro was a favorable offset. You might still have to "roll" the lip on the inside of the rear wheelwell , You didn't specify whether or not you're using a 8" wide or 10" rim. The 10" rim spreads the side walls of the slicks out some. While fitting this arrangement into your wheelwell check that the tire doesn't hit the forward part of the leaf spring also. This worked back in the 80's when we were first building theses cars and had to use "stock length" shackles.
Just more stuff to check, I hope this helps. Over the years the " 9 x 30 " slicks we use have grown some in size. Therefore fitting them where they belong has become a slightly larger challenge. The Camaro body has been an easier body to fit tires under then the Nova body. Its possible the back is too low or you'er trying to make the ride height to low, helping to exasperate the problem. There should be plenty of Camaro racers on this forum that can point you in the right direction.
Good luck and I hope some of this helps, have a Good Day.
P.S. this was done on stock leaf springs not aftermarket springs, Multiy and Mono leaf springs at the time.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 11-14-2022, 11:46 AM   #5
John Dinkel
Liked 263 Times in 68 Posts
Ask Calvert for a for a spring that will raise your car 1 inch higher.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 11-14-2022, 01:00 PM   #6
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
Not trying to steal your thread but I have some new -1 rear-half Calvert monos to get rid of if anyone wants them. They are new, powder coated black and fit camaros/novas.
Troy Henderson is offline   Reply With Quote
Old 11-17-2022, 06:46 PM   #7
Liked 10,747 Times in 2,235 Posts
Yes on the Cuda
