Liked 205 Times in 93 Posts
any way of determining 1st, 2nd ratios with an assembed unit? tks
Liked 753 Times in 213 Posts
No answer after 275 visit ???
I may be completely wrong with that and I never played with an auto transmission but I will try a tentative solution here. The standard gear set for a TH 350 is: 2.52, 1.52, 1 to 1 or 2.75, 1.52, 1 to 1. That means if you put your trans in first gear and turn the input shaft 2 and a half rotation (2.52), the output shaft should turn one rotation and so on (1.52 and 1 of rotation for the input shaft, for the second and third gear, should give you one rotation for your output shaft). You can make a tool with an old trans yoke and work on the output shaft side. Make 1 turn from your output shaft and count the rotation of the input shaft. I repeat, I may be totally wrong but it’s the way I see it. |
#3 | |
Liked 747 Times in 136 Posts
Yes, but you would have to apply/release the various clutches. You could use compressed air in the proper test ports to do so. |
#4 | |
Liked 1,103 Times in 301 Posts
Liked 5,121 Times in 1,952 Posts
You should be able to do this with air pressure. The rear most port ,behind the servo is main pressure.
Screw in an 1/8 pipe nipple and plumb an air hose to it..Give it all you got. Put it in manual low, and it should put the fwd. and lo/rev clutches on. Put a vise grip on the input and a yoke in the rear. 2 and 1/2 turns should be easy to count. If it doesn't work , the seals could be bad or maybe a reverse valve body..Try the 3rd position . Don't worry about 2nd if it shows 2.52 low.
