Old 01-14-2022, 04:12 PM   #1
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default part# 34G10 Griner billet Valve body in a TH400
I'm running a part# 34G10 Griner billet aluminum Transbrake Valve body in a GM Turbo 400.
I know they are no longer made. My question is, does anyone have a source for a replacement solenoid? TIA...
Old 01-14-2022, 05:58 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: part# 34G10 Griner billet Valve body in a TH400
Is it an external solenoid or an internal solenoid ? You may be able to call up Coan and ask them also .
Old 01-14-2022, 07:23 PM   #3
FED 387
Liked 333 Times in 180 Posts
you might try Cope Racing Transmissions in Indiana 219 -374- 0100---he has made a "new" solenoid that replaces the Griner unit for some Transmissions not sure if a TH 400 is one--- but his unit uses a new machined aluminum billet solenoid housing and a common Powerglide solenoid--- as you know Griner died a while back and the solenoids he supplied HE PERSONALLY made each and every one so the source and the secrets went to the grave with him---I would call Cole and see if he can help since no one else seems to be making solenoids any more--- Good luck FED 387
Old 01-14-2022, 08:09 PM   #4
CMcAllister
Liked 920 Times in 259 Posts
Hutch's Transmissions. Ontario. https://hutchtrans.com/index.html 519-453-4318
Showing the Griner 400 stuff on his website.
This guy got his Mopar stuff. He may be helpful also. He is In Indiana.
http://www.727specialist.com/ 219-718-3542
Old 01-15-2022, 11:59 AM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 885 Times in 238 Posts
check with ATI , they were selling the Griner valve body for a while.
Old 01-15-2022, 03:54 PM   #6
rallye bob
rallye bob's Avatar
That is who I purchased mine from....
Old 01-15-2022, 03:52 PM   #7
rallye bob
rallye bob's Avatar
internal solenoid
Old 01-15-2022, 09:16 PM   #8
ss3011
ss3011's Avatar
Originally Posted by rallye bob View Post
internal solenoid
The system is so simple , can you tell if the solenoid is shorted or is an open circuit ? Is the connection to 12v complete or is it possible the transbrake switch is not making contact ?
Old 01-14-2022, 07:19 PM   #9
mschafer
Liked 13 Times in 9 Posts
Smile Re: part# 34G10 Griner billet Valve body in a TH400
4 years ago I sent my Griner trans brake solenoid to Extreme Automatics in Amelia, Ohio and had my solenoid rebuilt cost $100 then and haven't had any problems with it.Phone # 513-898-0553
mschafer is offline   Reply With Quote
