Old 01-11-2022, 10:48 PM   #1
Jeff Stout
Liked 706 Times in 283 Posts
Default I D help for sbc
Stamp on front is FC 208 SA
Shows 69 327
Block casting 3792870
Shows 62 to 65 327
Head casting 3731539
Date D 9 7
Intake 3844459
Shows 300 HP Intake
The block numbers are confusing me on the year.
Heads are power pack with square and triangle on front.
I'm assuming mis match of parts and if heads or intake are worth good money I would remove from block.
If they are nothing special they will stay on block.
Engine going into 1952 jeep.
Thank you for your input.
Old 01-12-2022, 07:33 PM   #2
Jeff Stout
Default Re: I D help for sbc
Found out today the intake is the good one for 283 combo. 3844459. If anyone is interested let me know.
Old 01-12-2022, 08:25 PM   #3
killintime6968
Liked 91 Times in 29 Posts
FC could also be 1957 283 4bbl powerglide
Bruce Cameron
68 Nova 396 E/S
68 Camaro SS/? ex Checkmate Modified
killintime6968 is offline   Reply With Quote
Old 01-12-2022, 08:31 PM   #4
BillK
Liked 30 Times in 17 Posts
SA shows as 1962 Full Size car. If you are looking at the FC that is the prefix and does not denote the block use. Only the SA suffix.
3972870 Block shows 62-67 327
3731539 head shows 55 - 67 265/283
Bill Koustenis
BillK is offline   Reply With Quote
Old 01-12-2022, 10:23 PM   #5
Jeff Stout
This makes better sense.
Old 01-13-2022, 04:57 PM   #6
Adger Smith
Liked 880 Times in 311 Posts
Jeff, are the valve cove bolt holes staggered, top/bottom or straight across?
If my memory is working correctly I believe anything after '59 is straight across. Staggered would be pre '59.
Adger Smith (Former SS)
Old 01-13-2022, 06:03 PM   #7
Jeff Stout
Staggered. There are nice shape Corvette covers with 1 small chip on 1 fin
Looks like Billk figured it out. 62 67 block 55 to 67 heads. So actually 55 to 59 heads by the staggered bolt holes
