Liked 54 Times in 33 Posts
Yes, Lifter failure prevention....
Does anyone know or can someone find out what the hyd flat tappet lifter hardness should be so we can test them first? I have a hardness tester. Most engine shops do. I've got to find this out and soon. Not worried about making a small mark on the side of the lifter close to the bottom when testing. Easy to smooth out. |
#2 | |
First, you need to have some understanding of metallurgy and have knowledge of the material you are testing and any finishes and treatments. Many materials will change its original properties after being exposed to chemicals, heat and mechanical impact. |
#3 | |
Liked 232 Times in 108 Posts
#4 | |
Liked 253 Times in 95 Posts
George Mirza D/SA 1236 ‘71 Duster 340 Last edited by Gmirza; 01-07-2022 at 10:10 PM. |
I need to let you all know, I was a mechanical nuclear inspector for 7 years. Working with all kinds of exotic metals. I used to teach guys how to use a hardness tester. So thanks for the dire warning of what I might need to know, but I got it covered. And thanks for the numbers Terry.
Wonder what happen to Schubeck's tooling?
#7 | |
Sorry, please continue, these recent threads have been interesting
KEITH MAYERS 2-1/2 X somebody Still many X nobody Last edited by Keith 944; 01-08-2022 at 10:47 AM. |
Liked 227 Times in 74 Posts
Soo I would guess Lifters failing is still an issue? I have read Lifters are too soft and failing. Is this a material problem or a machining problem?
Liked 869 Times in 165 Posts
Lifter failure is definitely still an issue. That being said when you read all of the stories online of how people are wiping out lifters left and right, I would personally take them with a grain of salt if they don't specify things such as if they used proper assembly lube/break in oil, valve spring pressure, and break in procedure. I do however believe that there are some lifters out there that are inferior to others. I recently made some discoveries regarding who manufactures certain brands of lifters nowadays and was able to buy new Johnson solid flat tappet lifters even though Johnson does not sell them direct anymore.
1189 F/SA Defunzalo Racing Enterprises |
