Liked 34 Times in 12 Posts
Anyone know who makes a clean neutral valve body for TH350. I have fresh trans with standard reverse pattern valve body. Want to change so I can use as backup for my ProTrans TH350.
#2 | |
Liked 520 Times in 176 Posts
I believe that Coan makes a valve body for the TH350 with a clean neutral. You might want to investigate Turbo Action, Paul did a ton of work on those transmissions over the years. Maybe give Chris or Craig a call at TSR they might be able to help you out also. Good luck and happy hunting. Respectfully, Henry Kunz 1534 H/SA |
Liked 367 Times in 81 Posts
Try Rossler as well.
Liked 315 Times in 178 Posts
Liked 48 Times in 13 Posts
Just got one from Coan.
