Liked 20 Times in 15 Posts
considering a new 1956 265 build. have ?s
can you use: electric fuel pump electric water pump electric fan aftermarket oil pan with a kick out homemade deeeep oil pan 305 Chevy block with a 3" stroke crank, but big mains can you really run a 4 speed, legal, in a '56. very important are the rear axle choices still '56 or 12 bolt thanks Rod in AZ |
Liked 8,226 Times in 1,538 Posts
[QUOTE=rod;650660]considering a new 1956 265 build. have ?s
can you use: electric fuel pump electric water pump electric fan aftermarket oil pan with a kick out homemade deeeep oil pan 305 Chevy block with a 3" stroke crank, but big mains can you really run a 4 speed, legal, in a '56. very important are the rear axle choices still '56 or 12 bolt thanks Rod in AZ[/QUOTE ….Before you buy anything, you NEED a rule book .. |
Liked 5,153 Times in 1,967 Posts
Rod, I suggest you go up to Vegas for the National or divisional.
Lots of guys will be glad to answer all those questions. Just don't bother them til about beer:30
Liked 1,002 Times in 203 Posts
Rod, First off you need to get a rule book and read up on Stock eliminator. Second I would suggest you do the 305 block with the spacer bearings as that solves a lot of problems with finding a good 265 block and dealing with the starter mount, main seal, oil filter adapter etc. I have done a 265 that way and it works fine. Also with a 265 original block you have to use a forged crank so it will clear the internals of the block. 305 block doesn't have this problem. Any 265 ,283 crank will work.
Probably would want a steel crank with a stick though.
For what its worth, not sure there are any GOOD factory 305 blocks out there..
