Old 09-07-2021, 05:33 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default TorqueHead vs Opti
Can a Torquehead System be used in place of an Opti - PCM In Stock?
Old 09-07-2021, 05:59 PM   #2
GUMP
Default Re: TorqueHead vs Opti
No. You have to run the Opti Spark. You are allowed a crank trigger. The Opti Spark works just fine.
Old 11-10-2021, 01:18 AM   #3
Dan Fahey
Dan Fahey's Avatar
Just spoke to Tech Director Pat Cvengros.
Cannot use crank trigger in Stock with an Opti
can in Super Stock
Old 11-10-2021, 08:55 AM   #4
GUMP
can in Super Stock
The crank trigger has been allowed in Stock for the LT1 since the 1990's. I built and raced three LT1 F-Bodies. All with crank triggers. I can't remember how many times I was torn down. I never had an issue.
If you want run a stock ECU, go ahead....
Old 11-10-2021, 09:35 AM   #5
KRatcliff
Liked 534 Times in 143 Posts
can in Super Stock
Gump is correct. Under section 8 for Stock in the rule book:
DISTRIBUTOR
Any battery-operated, stock-type ignition permitted. Crank trigger systems prohibited unless OEM distributorless ignition. Distributorless ignition must retain OEM number of coils. See General Regulations 8:3.
In this case for your LTjuan the Opti is considered distributorless and a crank trigger is permitted.
One of the issues with the TorqueHead is the multiple coils. I don't know why you would want them over a single coil, but that is beside the point. Your combo only came with a single coil (it is plenty) and that is all that is permitted.
KRatcliff is offline   Reply With Quote
Old 11-10-2021, 11:10 AM   #6
GUMP
I will add that a GOOD aftermarket ignition box and coil is worth the investment.....
Old 11-10-2021, 11:14 AM   #7
Dan Fahey
Dan Fahey's Avatar
DISTRIBUTOR
Not really concerned about the multiple coils.
Do not understand NHRA’s reasoning but that is the rule.
It is a nice bolt on system and ECU easy to tune.
Our B-Body clubs like them.
Especially the Boosted crowd.
Agree single Coil is enough.
Until this weekend was fine using TunerCat for ODB1 PCM.
Been a 15 year labor of love learning most of the Files.
Excellent ECU. Opti is reliable.
Just discovered it’s limits.
Thanks for the help.
D
Old 11-10-2021, 11:17 AM   #8
KRatcliff
D
I use the Holley Opti replacement and I am not aware of any limits I have encountered so far. Can you elaborate?
Old 11-10-2021, 12:03 PM   #9
SSDiv6
D
Dan,
With all due respect, in lieu of trying to reinvent the wheel. Listen to the guys that are running the Opti-Spark system. On the long run, it will be more reliable, better performance and cost effective.
