Old 08-30-2021, 10:05 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default Closed loop?
B/SA. Lt1. What should I set my correction limits to. Been running open loop in alpha N. Just kicking around idea of putting it in closed loop. Any advice. I Know nothing about closed loop.
Kdw1403 is offline   Reply With Quote
Old 08-30-2021, 10:29 PM   #2
KRatcliff
Liked 534 Times in 143 Posts
Default Re: Closed loop?
I wouldn't run closed loop on a bet. I prefer Alpha N/Open loop by far.
KRatcliff is offline   Reply With Quote
Old 08-30-2021, 11:55 PM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Why not?
Old 08-31-2021, 06:37 AM   #4
KRatcliff
There are multiple reasons why I wouldn't run closed loop. The ECU can calculate very quickly, but the information coming into the ECU isn't reliable nor can the ECU read the information and make the necessary change to improve the performance within the short time of the pass in my opinion.
Our passes are only a few seconds and they are even shorter when you consider the gear changes. The ECU would have to make these adjustments reading off a single O2 sensor that isn't exactly in a sealed environment and it is only reading on bank of cylinders for an average. Plus the O2 sensors don't exactly like the fuel that we run.
When you consider these factors the ECU would be behind the curve in reading the data, calculating the change, and then effecting said change. I tune our cars in Alpha N/Open Loop in 10 different sections (for a 3 speed). The 2 Step (this would be chaos for closed loop) and 3 sections for each gear for a total of 10.
My fuel map leads in at each section similar to how we all use timing advance. There is also a cumulative affect that needs to be considered. None of this is possible with closed loop in our applications in my opinion. If closed loop was an advantage down track the Pro Stockers would run it. Closed loop is best suited for street cars.
Old 08-31-2021, 08:45 AM   #5
Jeff Niceswanger
Liked 1,051 Times in 372 Posts
Hi Kyle !
Kyle and I disagree on this one. It's like Chevy and Fords. There are two distinct different theories. I do not tune in Alfa, as its old school. Very similar to a Carburetor. It repeats and does the same exact thing every run. And many people prefer that approach. When your running a carb, you have the availability of rods and jets to stay on target. Air goes from 1000 feet on Thursday to 3000 feet on Sunday, you can change rods. The Alfa on open loop is locked into what ever tune is in it.. It just repeats.
I use VE, usually with a Alfa idle circuit. All the low RPM #'s are in Alfa with a separate Alfa Map,. But as soon as you start getting into the higher RPM's it switches into VE. VE is just a glorified Speed Density Program. On some tunes I stay with Speed Density, as I already have pre made tunes that are really close to the customers combos (in SD). Its just easier and quicker to use one of them. I've seen no advantage ET wise in either of the two.
The trick is to get the tunes to where you can feel confident you need no Closed Loop Compensation. That includes burnout, and slightly after (milliseconds) you go full throttle after launch.
That way, you can set your Closed Loop Compensations very low, like 3 or 4 percent, and know that the tunes will stay dead nuts during the entire run. Even IF, the air changes. If you look at your Data after the run and your car was using more than that 3 or 4 percent of adjustments, then your tune is not correct. You will know that as your Learned Compensation is 4 percent in places and your Target will be slightly off. Reason being that 4 % was not enough and the CL "Could not get there" . There are dis advantages to having CL active. IF the 02 fails, and they do occasionally, the 02 always fails lean. Meaning the Holley will think it's in a lean condition and puts all what's available in the tune. In this case all 4 %. But if your up high, like 50%, the car will instantly go full rich, die or be impossible to keep running. If it does run, it will be horrible. Its not a bad idea to change 02's occasionally if your depending on your 02 ....
Hope this helps...
Jeff Niceswanger 3740 SS
Old 08-31-2021, 09:46 AM   #6
KRatcliff
Originally Posted by Jeff Niceswanger View Post
Hi Kyle !
Hope this helps...
Jeff,
Nice that you weighed in and your points are well taken and you bring up some things that reinforce why I tune ours in Alpha N/Open loop. Your comment about it being old school and somewhat like a carburetor is correct, but that doesn't make it necessarily a bad thing.
Electronics are quite fickle and hard to diagnose in many cases. Nothing is more electronic than an ECU relying on electronic sensors and prone to gremlins than in our environment in my opinion. Alpha N/Open loop is much like a mechanical gauge vs and electronic gauge with Speed Density/Closed loop. Blown cars have to use Speed Density, but I am referring to our NA combinations.
Our sensors are not always reliable like the throttle position sensor that is key to Alpha N for example. I block out our fuel map to have the same MS pulse width from about 75% throttle all the way to 100% incase I have a TPS that is being touchy. I know that the throttle is wide open going down track so it won't matter if the TPS is showing something like 81% or something. I don't want it to lean out on me by mistake.
My approach is somewhat like trust, but verify and count on some failure by sensors at some point. Another thing about my tuning approach is that you immediately know if it helped or hurt. I don't want the ECU acting like Hal on 2001 Space Odyssey saying "Kyle, we are not going to run fast today."
Old 08-31-2021, 09:05 AM   #7
Robin Lawrence
Sponsor
Liked 717 Times in 121 Posts
Best answer is "it depends". I have many cars running in closed loop that are very consistent. It also depends on the ECU. We have been told that ours corrects faster than many others. Our hardware and software guys say it also depends on how the code it written in addition to the speed of the ECU.
Alpha N is great on applications where you have a very large cam. Where there is little vacuum at idle and no resolution. Speed Density allows for baro changes. If running Alpha N you should have a baro offset table.
I run my stocker with a Combo program. It is Alpha N up t0 2000 RPM and 20% Throttle Position. After that it is in speed density. I typically see less than 2% correction in closed loop.
To answer the OP's question, as far as setting limits in closed loop. I would suggest 10% additive or + and limit the negative to 5%. As 02 sensors degrade from race fuel the 02 will tend to show lean thus adding fuel. I recommend installing new 02 sensors annually.
The ability to correct with little latency will depend on your combination. On dyno we can see very fast response at sweep rates 300 to 400 rpm per second. Most sporstman cars engines will accelerate in that range in higher gears making closed loop function very well. In Pro Stock the engine acceleration rates can be upwards of 2000 RPM in the lower gears. I did not recommend that they use closed loop. I had several teams that enabled closed loop only in 4th and 5th gear.
I don't enable closed loop in my Mustang until 6000 RPM. With almost no collector after the 02 sensor it doesn't give good information at low RPM.
Of course this is my opinion. Results may vary.
Robin
STK 308
SS 3088
Robin Lawrence is offline   Reply With Quote
