Old 08-26-2021, 06:21 PM   #1
MoJo Risen
Liked 148 Times in 54 Posts
Default Spark Plug Heat ranges, what gains have you made?
I run a turbo car with a enhanced tune.
Boost is 16.5psi now from 14.1psi.
I have tried all variations of VP UNLEADED RACE fuel.
I find it difficult to see a performance difference in any as opposed to Costco fuel with VP octane booster.
I do have data that leans toward when I use VP C9 or MS101 AND BRACKET RACE THE CAR IS MORE CONSISTANT, EASIER TO DIAL.
I digress, my goal is to gain more from a colder plug than standard plug.
The NGK codest plug is 3 heat ranges colder than my stock plug.
I think it will be worth a tenth in my vehicle.
Thanks in advance for your input.
MoJo Risen is offline   Reply With Quote
Old 08-27-2021, 08:18 AM   #2
curtis reed
Liked 125 Times in 59 Posts
Default Re: Spark Plug Heat ranges, what gains have you made?
You think there is a tenth only from the plug change?
This may not be the best forum for a turbo charged question but there are a bunch of really smart guys on here.
curtis reed is offline   Reply With Quote
Old 08-27-2021, 10:08 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
Enlighten me.
I'm not up on boost terms, but what is an enhanced tune?
Adger Smith (Former SS)
Old 08-27-2021, 02:05 PM   #4
GTX JOHN
I think there may be a small improvement in performance
if the engine is running in or on the edge of detonation.
John Irving
741 Stock
741 Super Stock
Old 08-27-2021, 02:11 PM   #5
Jeff Stout
Liked 706 Times in 283 Posts
All reason to go faster with correct plug on nitrous is having the wrong plug and torching electrode.
Old 08-27-2021, 03:08 PM   #6
MoJo Risen
Originally Posted by Adger Smith View Post
Enlighten me.
Enhanced tune for my vehicle is, running ignition Timing right on the edge of pre ignition.
Old 08-27-2021, 03:18 PM   #7
MoJo Risen
I also forgot to mention the colder plugs vs the standard plugs give me a full CC less combustion chamber volume.
This increases static combustion ratio, almost always positive.
I feel like stockers should be able to submit their own spark plugs to compliment the shape of their combustion chambers, just like people submitting their own piston variations in Stock.
Btw...
Has anybody been caught moving their piston pin offset/location in Stock yet?
Old 08-27-2021, 03:59 PM   #8
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
A wrist pin offset normally is 0.060" to 0.080". When people reverse the wrist pin offset (do people still do this in stock?) this moves the pin center line 0.120" to 0.160" they may see a very small difference. Lets look at a 0.060" reverse and we a talking a little under 1 degree change in Piston TDC to crank journal TDC
Bore = 4.0 Stroke = 3.25 Rod Length = 5.7
Actual Piston Stroke 3.25019600382
Cylinder Volume 40.843168 CI 669.299602 cc
Engine Size 326.745340 CI 5354.396814 cc
Wrist Pin Offset = 0.06
Crank Angle Piston TDC -0.46932221356 Piston BDC 179.15635067565
Wrist Pin Offset = -0.06
Crank Angle Piston TDC 0.46932221356 Piston BDC 180.84364932435
Where you can really see a difference is with an inline motorcycle engine where the crank line has been moved 10 mm.
Stan
Old 09-01-2021, 09:12 PM   #9
Bruce Fulper
Liked 54 Times in 33 Posts
"on the edge of pre ignition" ?? Detonation and pre ignition are two very different things. Pretty sure you meant detonation.
Bruce Fulper is offline   Reply With Quote
Old 09-01-2021, 09:51 PM   #10
MoJo Risen
No Bruce, it's a TURBO car, high Combustion pressure.
Turbo cars have a tendency to have low speed Pre ignition with much higher Combustion pressure....
But, I am here to gather ideas and have looked further into detonation.
I can see how they can be confused with one another.
Thank you for the response.
I do look forward to the NGK heat range 9 plug to test.
