Old 08-01-2021, 05:15 PM   #1
Mike Savelle
Liked 7 Times in 5 Posts
Default off idle stumble
installed a Holley 3310 on our crate motor and it stumbles bad when staging , but when it gets to 2700 it smooths out and had our best 1/8 mile pass on this motor . Any help appreciated . Mike
Mike Savelle is offline   Reply With Quote
Old 08-01-2021, 06:52 PM   #2
L.Fite
Liked 498 Times in 244 Posts
Default Re: off idle stumble
Carb stumble/bog,
Things to check...
Accelerator pump adjustment.
Squirter size.
Vacuum secondary opening rate.
L.Fite is online now   Reply With Quote
Old 08-02-2021, 09:30 PM   #3
Eman
Liked 133 Times in 76 Posts
On my 3310 making sure the transition slots on the primary side aren't exposed too much. Flip the carb over and see how much of the transition slot is showing on the primary side. If it's more than square look at the secondary slots. If the secondaries are covering the transition slot open the blade adjustment enough to square the slot. Then you can lower the idle screw and go from there. Might still need to richen idle screws and possibly increase squirter size. Be sure to adjust the spring on the acc. pump lever and if needed put a diaphram and check valve in the pump.
Old 08-03-2021, 07:47 AM   #4
Ralph A Powell
Liked 226 Times in 137 Posts
Not more than .060 of the slot showing. Does throttle blades have holes in them for more air at idle?
Ralph A Powell is online now   Reply With Quote
Old 08-03-2021, 10:32 AM   #5
Dyno
Dyno's Avatar
Liked 694 Times in 206 Posts
Bump the squirter up to a 35 or 37. Use the purple spring in the vacuum diaphragm.
Old 08-04-2021, 12:57 AM   #6
6130
Liked 117 Times in 50 Posts
The 3310 is an awfully forgiving carburetor- I've used them on everything from 302s to 460s, and they've always worked great, right out of the box...
