Liked 950 Times in 189 Posts
Having some problems setting the front end on the 55 Chevrolet project. The guy that has done my front ends before can't get the caster ,which is suppose to be around 0 degrees, any closer than 2 1/2. He says the front frame saddle may have to be spread, or the upper A arms may have to be modified to get close to the specs. Any one have any suggestions on this problem? Thanks Lyn
Liked 26 Times in 15 Posts
2 1/2 positive or negative caster now? If I remember, shims on C.A. mounting bolts? Is C.A. shaft inside or outside of frame brackets?
Victor in Kingman |
Found an image of front suspension online. An original car that with no shims. Been almost 50 years since I worked in a front end shop. Have not paid anyone to align my cars since. I remember some cars did not have much range of adjustment. Pulled all shims out to just get as close as we could. Frame bowing inward from road shock?
Ideas: after market offset upper control arm bushings available?. Check the LOWER control arm mounting points too. Moving those corners will have the same effect on camber/caster. Effort spent checking on camber and toe in change throughout suspension travel pays BIG rewards. Victor in Kingman |
Liked 329 Times in 177 Posts
2 ways to correct that
A) buy offset upper control arms --- from Danchuk or similar B) cure the crossmember sag ----chain the outer parts of the frame and put a hydraulic jack under the front crossmember and give it a few pumps usually one at a time to correct the sag which raises the crossmember If you do A the sag will still be there and eventually you will need to resort to B to get it back into specs TRI 5's are famous for doing that --sagging FED 387 |
#5 | |
Liked 5,076 Times in 1,935 Posts
2 1/2 deg. POSITIVE caster would be minimal on a drag car.
Liked 66 Times in 30 Posts
Tri-Five Chevys are known for this. I solved it by using these on my '57, they are OEM-style repros with extra caster built in.
https://www.classicchevy.com/chevy-u...-344513-1.html |
Thanks Jeff. I did not know about the upper arms with the 5 degrees built in to them. In fact I was in the process of building some with the ball joint moved. I will just get some of these instead. Will let you know how they work.
