Liked 51 Times in 30 Posts
hi,
stock eliminator nhra still doing fuel check?? do i need a tap off fuel line next to carb? does someone sell a kit, i can most likely make one with brass fittings and petcock Gary |
Liked 237 Times in 126 Posts
I bracket race but a lot of my competition is from NHRA legal S-SS cars. I have it after the regulator under the hood. I've seen it done on the cheep with hardware store fittings and $100 billet aluminum stuff that leaks. Long story short: if it's in the book, you need it. Checking it is up to the tech.
#3 | |
If you have an EFI fuel system, that exceeds 60 PSI of fuel pressure, then you need the Aeromotive Sampling valve. The Saf-Air fuel sampling valves are FAA approved and used in general aviation and affordable and even sold with a hose by RJ Race Cars. They have a brass and stainless steel version and have Viton seals. https://www.aircraftspruce.com/catal...ircav110h4.php https://www.mcfarlaneaviation.com/pr...roduct/110HSS/ https://quartermax.com/fuel-sample-valve/ https://www.appliedracing.com/an-fit...ple-valve.html https://www.speedwaymotors.com/AFCO-...CABEgJOYvD_BwE |
thanks for the links
Liked 171 Times in 51 Posts
Its really handy to have a way operate the fuel pump from the engine compartment, not required just handy. I use a momentary switch wired to the pump that I installed on the fender apron.
Kelly Lane 4991 STK
Kelly Lane Stk4991 |
#6 | |
The rule book specifies that the fuel pump must shut off with car’s ignition switch. |
It’s a dedicated switch that operates the pump independently of the ignition switch.
Liked 254 Times in 78 Posts
I have the same, very handy, make sure to use a momentary switch. I don;t have a return line on the pressure regulator, so I use that outlet and hooked up brass fittings and a brass shutoff used for an icemaker line.
Mike Moller NHRA 203 Q-R-T/SA |
Liked 253 Times in 95 Posts
I use a fuel shut of for a Motorcycle. The type that screws into the bottom of the gas tank. It’s the same pipe thread as the outlet port of the regulator. Put a length of rubber hose on the barbed end.
George Mirza D/SA 1236 ‘71 Duster 340 |
