Old 01-24-2021, 08:24 PM   #1
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
Question Valve spring pressure
On a dual valve spring with the inner spring slightly shorter, when checking spring pressure with rimac tester, do you need to account for the inner lip from retainer. When spring is on head and closed, the inner spring is not at same level as outer. Valve spring tester is flat and contact with inner spring is about .060 lower. I know I'm rambling, but maybe someone understands my question. Thanks.
Ed McLawhorn Jr. is offline   Reply With Quote
Old 01-24-2021, 08:46 PM   #2
Paul Precht
Paul Precht's Avatar
Liked 307 Times in 116 Posts
Default Re: Valve spring pressure
I use a .100" washer, a lot of retainers have a step about .100".
Old 01-24-2021, 08:51 PM   #3
Ed McLawhorn Jr.
Paul, I have used a washer and seen dad do same for years. I didn't know until recently how much difference it makes if you leave it out.
Old 01-24-2021, 09:00 PM   #4
BillK
Liked 30 Times in 17 Posts
Like the others said, you need to check it the same way that it will be installed. Same retainer and some type of shim to simulate the step in the head. What you really need to pay attention to in that setup is coil bind on the inner spring.
Bill Koustenis
BillK is offline   Reply With Quote
Old 01-25-2021, 02:57 AM   #5
outlaw
outlaw's Avatar
Liked 132 Times in 52 Posts
I have used a quarter many times.
outlaw is offline   Reply With Quote
Old 01-25-2021, 07:09 AM   #6
SGSST109E
Liked 126 Times in 61 Posts
I always check mine using the retainer
SGSST109E is offline   Reply With Quote
