Old 12-23-2020, 03:48 PM   #1
68Coupe
Default question about brakes
I have a 68 mustang that I bracket race and it has stock drum brakes all the way around. I am thinking about swapping over to disc brakes, looking at Wilwood and Strange.
I have heard different numbers so I'm wonder if i were to swap how much lighter are the disc how much weight can i expect to shed.
68Coupe is offline   Reply With Quote
Old 12-23-2020, 04:52 PM   #2
427FE
427FE's Avatar
Liked 348 Times in 79 Posts
Default Re: question about brakes
I hear 40-45 lbs for just the front
427FE is offline   Reply With Quote
Old 12-23-2020, 05:39 PM   #3
Dan Walcott
Liked 92 Times in 26 Posts
On my 62 Plymouth Sport Fury , Remove 4 drums/backing plates ,ect , install 4 disc brake assemblies master cylinder ....saving of 60 lbs
PLUS NOW YOU CAN STOP !!
Dan Walcott is offline   Reply With Quote
Old 12-23-2020, 05:45 PM   #4
Randy Wells
Liked 1,144 Times in 354 Posts
Just installed Strange brakes on my 80 Camaro, 48lbs plus another 7lbs changing out stock master cylinder to a Strange unit. And 22lbs for the rear. 77lbs total
Randy Wells
I/S 5628
Randy Wells is offline   Reply With Quote
Old 12-24-2020, 12:27 AM   #5
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
My 68 Coup started out with drum/drum street brakes and I dumped them for Wilwood street disc/disc. Dropped around 45-50 pounds. Changed them for Strange S series drag brakes and lost about another 10. Early Mustang stocker brakes are a huge mess.
Dale Shearon
68 Mustang 6394
Old 12-24-2020, 09:06 AM   #6
Nmbr1GMfan
Strange brakes don't retract worth a crap.
Todd Greene
Old 12-24-2020, 11:32 AM   #7
SSDiv6
The brakes with the lowest drag in the market is TBM.
The car will roll easier when compared to other brands including Lamb and Mark Williams.
https://www.tbmbrakes.com/
Old 12-24-2020, 12:13 PM   #8
ken robinson
Liked 224 Times in 87 Posts
The TMB brake co. sales a rotor hone tool . Any body tried it or you just cycling out rotors ? If your rotors pass run out test & other wise look good not discolored & still smooth when your replacing your brake pads do you do anything to your rotors [ bin on the car 5 yrs now ] ? .I run M/W on 4 now , it had drums on all 4, it was alot of weight cant remember the total amount , but from what the other guys posted seams about wright .
