Old 12-19-2020, 10:12 PM   #1
Adger Smith
Liked 880 Times in 311 Posts
Default Bearings/lube
There are a couple of threads on here about wheel bearing lube and rear gear lube.
That just brings up something I have noticed and am wondering what others think.
I have owned several cars built by others.
I have noticed that on the rear axle some have the wheel bearing's inner seal removed, others run with the bearing "sealed".
Anyone have any thoughts?
Adger Smith (Former SS)
Old 12-20-2020, 01:02 AM   #2
SSDiv6
Default Re: Bearings/lube
Adger,
Sealed axle bearings are used in many applications. FWD cars and late model cars with struts have sealed bearings that last for a long time. Non sealed bearings require additional lubrication just like in rear axles. What I have done in the past with sealed bearings is to pop out the seals, wash out the grease and replace the the original grease with a high end synthetic grease and put back the seals.
Old 12-20-2020, 01:32 PM   #3
Adger Smith
Joseph,
Something like This?
Kluber NBU 15
https://www.allworldmachinery.com/it...iABEgKiyfD_BwE
MicroBlue Heavy Duty Lubricant
https://www.microbluebearings.com/heavy-body-lubricant/
QuarterMax Bearing Grease (I believe is made by MicroBlue)
https://quartermax.com/rj-qmax-wheel-bearing-grease/
Old 12-20-2020, 01:41 PM   #4
SSDiv6
Joseph,
Kluber NBU 15
https://www.allworldmachinery.com/it...temCode=NBU-15
Adger,
Any of those will work with the Kluber NBU 15 being the best. It was developed for high load/high speed machinery and will deter corrosion and keep water away.
Check out the product sheet.
https://cnc-specialty-store.com/info...alty-Store.pdf
Old 12-21-2020, 02:00 PM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Must be good stuff at $100 a tube !
Old 12-21-2020, 02:34 PM   #6
SSDiv6
It's only $23.00/tube, not $100.00.
